Losi 1/8 8ight E 4wd Thread
#1426
#1428
It stops....for awhile and if there is enough re-bound voltage will run slow for awhile. 3.2 is good, I run 3.0 but never hit it as a result of being careful with my calculations.
Hey Chuck where were you yesterday? I was the lone e guy at rev.
#1430
That is my experience, it stops although I have only run the batts down to the lvc 2 times.
#1431
Do the nitro bodies fit the 8ight E?
#1433
My kids got sick so I could not come out and play!! Will be there next Saturday.
#1434
i have used the jconcepts nitro body and i have only overheated once in 3 years of having mine converted, and that is only with the 2 vent holes cut out.
#1435
I started out running my 2.0E with the stock race roller setup. I just changed the setup to Adam Drake's 08 Neobuggy setup. I really like how it drives now! I think the thing that changed it most was changing the center diff from 5k to 7k oil. It really has alot more on power steering. The only thing different on mine is I don't have the adjustable hinge pin mounts.
I'm still astounded at how good the Castle-Neu combo is working out. After a hard 10 min of running I put 1600 mah back in my 5s 4000 pack. The only issue I'm having is running it on my backyard track. It's tight for the 1/8 scale and even running it on 4s keeping the same gearing as 5s it's running on the warm side. I guess lower speeds are harder on the system.
#1437
Wow I really like where these brushless systems are going. I've always wanted the Kyosho Inferno buggy just because of what people have told me about it. Nitro always seemed the way to go, because you could refuel a lot easier and faster. But Nitro is pretty expensive! The cars in themselves tend to be on the messy side. Electrics on the other hand are a lot easier on maintanence per se, but its expensive to pile up on battery packs to have longer play time. Nitro exhaust has always irratated my eyes though.
It's still up in the air, as I haven't started saving for one yet. But the 8ight-E just may be a great birthday gift for myself when the time comes.
And it's so much cheaper than the MP9.
Doesnt seem like these cars would have too much of a problem competing with the gas versions...
#1438
It's on the Losi website.
#1439
#1440
I'm not running it on grass. I have a track in my backyard.
