Losi 1/8 8ight E 4wd Thread
#1306
I was thinking of a combination for a while also. I like how the RCPD batt tray only has one big velcro instead of 3 of them. Will make for quicker pit changes. The RCM or RCPD mount is a must in my opinion because of the shaft length, plus it seems some were having problems with the losi mount moving because of only 1 screw settings the gear mesh.
I am going with the RCPD esc mount above the rear driveshaft that why I might be able to get a heavier battery wo/ messing up the balance of the car were the losi has the esc and battery both on the side. I dont know if this has any real effect, just an idea. So thats what I did. Im still waiting on my RCPD conversion but I have everything else. Battery comes tomarrow.
The rx box is only like $10 so I would just buy a new one but Im sure you can cut the excess off the stock nitro one.
#1307
Is there any real difference between the losi e conversion rec box and the reg. box...can the reg. rec. box simply be cut off. I would like to do a losi b conversion and use the rc monster or rcpd motor mount but I like the batt, tray , rec. box, I think all the components seperatly but NOT use the Losi motor mount ..or just go Tekno Rc.
#1308
Teeforb, I would do the losi 1 because it is CHEAP...race roller 250.00 and I do not think the differences between the ver.1 and 2 on the buggy are that significant. The truggy 2.0 is much different then 1.0.
I will probably sell my mbx6.
The losi conversion , it seems, does have a motor mount problem as it relates to the neu,medusa etc. motors therefore I will go with the Monster or rcpd mount. The motor shafts do not go into the pinion far enough with the losi MM. I like the losi batt tray and the overall layout but not the motor mount.
Did you get the ver 2 truggy yet?
#1309
Imo there's More then enough improvement on the 1.0 to the 2.0 in buggy...the chassy alone is one of the best parts...next you add the upgraded alloy's..better brakes....shimable diff cases...radio tray...servo saver plastics....the list goes on.....
#1310
Nope, hopefully they will receive their shipment tomorrow and ship out the same day... Im going to see how the losi motor mount pan out for me.
#1311
Look what showed up today. Still need a body (the one that comes in the box has big holes in it for the nitro stuff) and I have not decided if I am going to use M3 or 8-32 screws to hold the motor onto the mount. Tapping new threads is not a problem but I noticed on the MMM motor the holes come very close to the endbell screws and there may not be enough meat on the endbell to provide support if I drill and tap for an 8-32 screw. Got to open up the motor and see what's on the other side of the endbell.
#1312
r40
try going up one tooth to a 14t
you might be undergeared hence you are heating up
did you also monitor the rpm via telemetry
I run in 80-90 degree heat here in south texas and use a 14t with the losi esc and motor and the motor heats up to 130s-140s after 12-15 mins of racing
I was getting less heat with a 16t but used a 14 to have more runtime
#1313
Guest
#1315
Guest
#1317
Guest
#1318
I am not comfortable with " just hitting the notch". I would not use the losi motor mount because of this issue with the neu motors, it may not be an issue but it is for me. There is too much torque with these motors to risk it. I suppose if I bought the conversion I would try t but I would plan on buying brand x to back it up.
Somebody mentioned a full chassis conversion for the losi from rc monster...I do not see it on there site. Do they have one?
There are pro and cons to all the conversion: the tekno needs there long pinions, the losi motor mount is ??? for neu's, rc monster only has the motor mount and rcpd puts the MMM on top. I think the best way to go is the losi batt tray ,rc monster mm, losi radio box and top plate. In other words everything losi but the motor mount-rc monster...unless you want a clutch then the tekno.
#1319
are you plan on doing this anytime soon? you can wait to see my project and see how it goes. i plan on running all losi conversion kit.
#1320
check this out...
http://www.rctech.net/forum/5302529-post8.html
also, PM i received...
Now, you will have to extend the notch on the shaft for the pinion to fit. I had to extend the set screw notch only about .100" to get my pinion to work perfectly. I use the Novak pinions, btw.
