Losi 1/8 8ight E 4wd Thread >
Old 01-11-2009, 05:45 PM
  #1096
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Yeah guys wat r u using for pinions. I am running a Losi pinion on my novak setup and wont stay on. First test run and pinion flew off. Then I reinstalled it and it came off again!
BuggyKing is offline
Old 01-11-2009, 06:00 PM
  #1097
carrera996's Avatar
BuggyKing,
Did you use thread lock on the set screw? Same thing happened to me several times, but after using a drop of thread lock, hasn't happened since.
Tom
carrera996 is offline
Old 01-11-2009, 06:46 PM
  #1098
tdeal823's Avatar
Trader Rating: 30 (100%+)
I use novak and losi pinions no problems here but I am using
the blue thread lock that comes in the glue stick.
tdeal823 is offline
Old 01-11-2009, 07:38 PM
  #1099
BuggyKing's Avatar
carrera996,
Hi I havent tryed threadlock. I will go ahead and try and see if it holds.
Thx Tom
Old 01-11-2009, 09:21 PM
  #1100
R40Victim's Avatar
I actually ended up using a tiny dab of red to get mine to hold. Just gotta get it red hot to break free is all.
R40Victim is offline
Old 01-11-2009, 09:41 PM
  #1101
BuggyKing's Avatar
so u gotta melt the pinion to get the set screw loose.
Old 01-12-2009, 06:40 AM
  #1102
Miller_Time's Avatar
Trader Rating: 11 (92%+)
I've been using the Losi pinions with blue loctite and it works fine. I did have one come loose before I started using some threadlocker so that is definitely recommended. I'll probably start using Novak pinions soon however for the larger set screw. Too easy to strip out the setscrew head with all the torque that is needed to break it loose.
Miller_Time is offline
Old 01-12-2009, 01:00 PM
  #1103
R40Victim's Avatar
Yeah, just about! Actually, it only took a little love and heat to get it loose, then it just came right on out.
I tried the Novak pinion, but I hated it. It was so gawdoffle noisy, I switched back to the Losi version. I also like the Robinson Racing versions much better:
http://www.amainhobbies.com/index.ph...filter_mfr=198
Old 01-13-2009, 10:09 PM
  #1104
BuggyKing's Avatar
Questions??
Hey guys,
Im on a 13t pinion on my 6.5. Wat r u guys running. Just wanted to get an idea to see if I were geared to high. Thx,
Matt
Old 01-13-2009, 10:30 PM
  #1105
R40Victim's Avatar
Novak? If so, typically in the 11-12T range, that is if you still run the stock spur. You may want to give the Kyosho 46T nylon spur a try. It worked best for the local guy running a Novak system.
Old 01-13-2009, 10:32 PM
  #1106
BuggyKing's Avatar
I am running the novak 6.5 with a Kyosho 46t spur. Maybe Ill try a 12t pinion.
Old 01-13-2009, 10:38 PM
  #1107
fukitol's Avatar
have you guys done any search on the nitro thread? so many of your problems are already worked out.
fukitol is offline
Old 01-14-2009, 07:35 AM
  #1108
Integra's Avatar
what problems ?
Integra is offline
Old 01-14-2009, 08:13 AM
  #1109
R40Victim's Avatar
Generally, the car is fine, we're just working through the bugs in the conversions. Minor details... typical growing pains of any brand new class of RC cars, and even more so with modded cars.
As for gearing, yeah, try a 12T. The local guy that ran Novak stuff recently switched over to the Losi system. If he was gonna do it again, I'd tell him to go with the CC 2200 Kv system.
Old 01-14-2009, 08:57 AM
  #1110
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Like gearing for a brushless system?
Software upgrades for an esc?
What lipo setup to run?
How to make racing fair for the nitro 1/8 scales again?
F N CUDA is offline
