Losi 1/8 8ight E 4wd Thread >
Old 12-31-2008, 10:20 AM
  #1006
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Clean surfaces and HOT soldering irons and it is done in seconds.
Pre "tin" the surfaces then just a touch gets it done.
Integra, you know I'm just havin fun right? I have imports too. Actually an Acura in the family.
F N CUDA is offline
Old 12-31-2008, 12:31 PM
  #1007
Matrix Concepts's Avatar
Trader Rating: 24 (100%+)
Default Carbon Chassis
I wanted to let you guys know about our year end blowout on our Carbon chassis for the 8ight. It would be a great addition for your 8ight-E conversions. The chassis is 100 grams lighter than stock regularly $199.95 now $149.95 while supplies last.
Attached Thumbnails Losi 1/8 8ight E 4wd Thread-rc-tech-2508.jpg
Matrix Concepts is offline
Old 12-31-2008, 12:55 PM
  #1008
rhino420
Guest
Posts: n/a
that chassie is so narley ! wish i had an extra 150 to get one... you guys want to sponsor me ? ha ha
Old 12-31-2008, 01:02 PM
  #1009
Integra's Avatar
X2 on a Hottt Iron and a Prepped surface...I use a scratch all or some sandpaper to Rough up any surface im soldering....i used to be a Car Audio tech...so yes ALL my solder joints are Purfect.
Integra is offline
Old 12-31-2008, 01:03 PM
  #1010
Integra's Avatar
Truggy truggy ?
Integra is offline
Old 12-31-2008, 05:55 PM
  #1011
The website has been updated with the blowout pricing.
Thank you and Happy New Year to everyone.
Robert
Old 12-31-2008, 05:58 PM
  #1012
Default Truggy
integra- The truggy chassis are available to for $179.95 while supplies last.
Old 12-31-2008, 06:18 PM
  #1013
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
glad to see apparently some things have been fixed or figured out b/c the 1 E8 i've seen, which is stock, is really fun to watch (still i hate marshallin 1/8s). yes it was racing on a 10 scale bullring, but on the other side it was enuff to send a E-caster up in flames. keep it up
R
UltegraSTI is offline
Old 01-01-2009, 09:09 AM
  #1014
Trader Rating: 46 (98%+)
Ok so I finally got to run this bad boy. Super fun is all I can say.
But now the bad news. My kit only cake with a 16t pinion. Im using a zippy 4s 5000mah pack. I took it to Thunder alley on tues and ran a few packs through it. It kept pulling the tires off the rim (shitty glue job thanks losi) so I took it to ARCraceway yesterday and it was running fine then it just stopped. I pulled it off the track to take a look
Here are the symptoms. When I give it full throttle it sounds like it is just cogging really bad and just sits there. If I pick it up it does the same but sometimes it gets past the cogging sound and then spins fine. I checked the motor temp and it read 201 yikes how the eff is that possible????
So now im confused not sure how to trouble shoot it. Not sure if the ESC is jacked or the motor or the diffs?
Any Help?
everyjuangohome is offline
Old 01-01-2009, 09:27 AM
  #1015
badassrevo's Avatar
Get a hold of Horizion and send your ESC and Motor back.
badassrevo is offline
Old 01-01-2009, 09:30 AM
  #1016
Shadizzle that sucks!!
One other question. I bought a losi 4s 5000mah pack on my way to the track, but of course my dumbass forgot to check the balance plug. I have a hyperion duo charger and the losi plug will not fit into my balance board. Do I need some type of adapter or what? Do i need to cut it off and set up a hperion plug where can I get these amain?
Old 01-01-2009, 09:35 AM
  #1017
badassrevo's Avatar
you will have to search this thread to find out what plug it is. I know it is here somewhere I read it. Once you know what plug it is just go to www.rclipos.com and get the adapter you need.
Old 01-01-2009, 09:43 AM
  #1018
Thanks.
Old 01-01-2009, 09:48 AM
  #1019
R40Victim's Avatar
My first one did almost the same thing. Send it back. The most laborious part of the fix, is soldering the new motor wires. Make sure they send them! Once installed, and updated with the new firmware, you'll be good to go.
R40Victim is offline
Old 01-01-2009, 09:54 AM
  #1020
BuggyKing's Avatar
Trader Rating: 17 (100%+)
WOW over 200 degrees, thats not good. Sounds like ur way over geared. R u running the 1700kv setup in it.
BuggyKing is offline
