Losi 1/8 8ight E 4wd Thread >
Old 05-16-2013, 06:26 PM
  #8596
purple haze's Avatar
is there a 8ight E 3.0 coming out ?
purple haze is offline
Old 05-16-2013, 06:38 PM
  #8597
KingdomRacer's Avatar
Sure will at 4:20pm on 4/20
Could not resist with that screen name
KingdomRacer is offline
Old 05-17-2013, 02:56 PM
  #8598
Trader Rating: 160 (100%+)
I was wondering if anybody has tried putting front arms, hub carriers and spindles from a 3.0 on there 2.0. I believe the 3.0 has 15 degrees of caster instead of the 20 degrees on the 2.0. Seems like it would be alot cheaper option than getting the aluminum inclined blocks if it works.
Chris Gierse is offline
Old 05-17-2013, 03:35 PM
  #8599
QuikWgn's Avatar
If you read the 3.0 thread, you see you have to basically swap everything from the towers on out not just the arms/carriers spindles... there are a couple of posts in there entailing all the part numbers needed to swap over to 3.0 suspension.
http://www.rctech.net/forum/nitro-of...ght-3-0-a.html
QuikWgn is offline
Old 05-18-2013, 03:42 AM
  #8600
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Cool 3.0 Stuff
http://www.rctech.net/forum/r-c-item...parts-new.html
XXXDad is offline
Old 05-19-2013, 06:24 PM
  #8601
Never mind my previous question , I will be buying tekno .
Old 05-19-2013, 10:00 PM
  #8602
XXXDad's Avatar
Thumbs up Its Out
XXXDad is offline
Old 05-19-2013, 11:29 PM
  #8603
Hellbound's Avatar
Trader Rating: 37 (100%+)
is this a converted nitro 3.0 ?
Hellbound is offline
Old 05-20-2013, 08:29 AM
  #8604
Has anybody converted their 2.0 to a 3.0? I was looking through the parts list and its seems like it would be cheaper than buying a 3.0.
Old 05-20-2013, 06:39 PM
  #8605
hey guys. just got my 8 2.0 ebuggy done & my gens ace 4s battery holds the body up (too tall). anyone run into this? should i just run it with battery pushing body up? will this damage the battery when i wreck? should i go down to 3s or 4s? haven't drive it yet still gotta bind radio. some insight would greatly be appreciated.
rubberneck is offline
Old 05-21-2013, 04:14 PM
  #8606
blade329's Avatar
Trader Rating: 114 (100%+)
The Gens Ace 4S is a pretty tall lipo. Have you tried laying it down on its side?
blade329 is offline
Old 05-21-2013, 07:26 PM
  #8607
no i haven't. good idea, i'll try that. thanks
Old 05-21-2013, 08:30 PM
  #8608
djbclk430's Avatar
Trader Rating: 59 (100%+)
Originally Posted by SC-Racer View Post
I bought my 8 E new a couple months ago. Since then I have ran it on an indoor track and an outdoor track. I haven't been very impressed with the buggy at either track. I decided to buy a rebuild kit and rebuild my diffs. They all felt very notchy and like they had about 10k fluid in Them. After I rebuilt them and broke them in I can't believe how different they feel. They are very smooth and you can actually feel a difference between the front diff with 5k and the rear with 2k. I'm looking forward to getting it to the track and to see what kind of difference this makes. The diffs were so bad I am planning on getting a shock rebuild kit next! Anybody else have this experience?
Yes I had same issue with my buggy all diffs were hard and notchy I rebuilt them and left the small metal washer off that goes above the orange o ring in diff, saw this on you tube Adam drake rebuilds diffs watch the video. They all were nice and smooth after that and no leaks, before the diffs leaked because they were not closing all the way!
djbclk430 is offline
Old 05-21-2013, 09:10 PM
  #8609
Trader Rating: 18 (100%+)
I left the shims in. Maybe next time I will build them without them. Does everybody leave those shims out?
SC-Racer is offline
Old 05-22-2013, 09:11 AM
  #8610
QuikWgn's Avatar
I build mine shim-less, as do most 8ight racers I know.
QuikWgn is offline
