Losi 1/8 8ight E 4wd Thread
#7802
You can find them used from $60-$90
not sure if your aware of this "servo info site" http://www.servodatabase.com/compare...=917,1552,1676
Al
#7803
ive just replaced my losi's rear diff bearing cups ,gearbox then shimmed it tight did yours stop clicking? my losi has been unreliable and always requires regular maintenance after every run, any tips for getting them to run sweet?
#7806
Ive ran my Buggy in E form for 3+ year's and my R+P looks like brand new, Little shiny where the teeth are riding.
#7807
I burned up 2-3 center diff gears over the past few weeks, and think I cleared it up with a new pinion gear. After comparing the new to the old pinion, it seems the old one was quite a bit more worn than I realized. Teeth were a bit rounded, couldn't really tell until I compared with a brand new gear.
I've got 1 qual and 1 main on it so far, so I'm not 100% certain that's the fix.
That said, what else can be done to maximize the plastic gear life span?
The space between the diff gear and the motor mount is very minimal, and the assembly doesn't seem to need shims (really no play, if I shimmed it seems it would only add friction thus heat). My motor's rotor has some play, enough that if I align the pinion and diff gear 100% I can push the pinion and have it hit the mount slightly. I could shim the motor behind the pinon, but no shims on hand, so I did dremel just a bit of material off the motor mount behind the pinion so that they don't touch.
I've also reduced brake travel/EPA on my radio and have been rolling the throttle smoother, and braking more conservatively.
Did I miss anything? I've been running the SCTE for over a year and that has the same engineering, though smaller - and have never had problems with my diff gears.
Losi pinions say '1.0 Module' on the package, and I was told that was different than Mod1, and is why I was losing my gears. Is that accurate? I run the same pinion on my SCTE with no issue, though that's a smaller center diff gear.
I do have a metal 45T on order, but hate to use that because I know that the plastic gear works. I just can't figure out why it's not working for me. Hopefully it was just the pinion.
#7808
#7809
I was stripping spur gears insane bad after going a year without stripping one. I went through like 4 spur gears in 3 heats and a main. It ended up being that the plastic center diff mount had stripped out and the center diff mount was lifting up off the chassis mount screw. I replaced the plastic center diff mount and WALA! No more stripped spurs.
#7810
1. I do not use the rear motor brace (Losi conversion)
2. I shim the diff off the motor mount
3. Shim the motor shaft (Avid sells the shims)
4. Longer screws on plastic center diff mount
5. Check for loose screws often
6. I do not mash the throttle or jam the brakes when down-siding jumps
Should be good!
#7811
Thanks for the ideas guys - I'll replace the center plastic mount and use longer screws and see where that takes me. I think I have everything else covered (ordered shims yesterday too).
I've been inspecting the gears now every run and they seem to be hotter than expected so I checked to make sure something wasn't binding and creating additional heat - IE: causing it to sort of do a slow-unload over the duration of a qual/main. I haven't temped them yet to get a baseline, so not sure if this is an indication of an issue or just normal. This weekend I'll have my temp gun with me. Part of my theory is the heat could be softening the plastic leading to early failure.
Tekin 1900 is running pretty cool at 15/45 on 4S, but I might see if a 16T on our medium to large track would take temps down a bit (to see if it's over spinning).
Seems like a aluminum center diff upright would help with stripping, and maybe even some heat dissipation (heat sink). Like they have for the TEN-SCTE: http://www.kingheads.com/product_inf...8b77e7ab694fc3
Time will tell..
Time will tell..
#7814
Ok so i tried the LOSI4415 center diff mount and it rubbed on the 44t spur.
Bought and waited for the LOSI4420 2.0 diff mount. it still rubs on the spur.
Not to mention 44/13 gearing which i ran on my last Losi 8ight 2.0 doesn't even touch on the Tekno V4 chassis...
44/15 works but the motor is all the way over and the mesh is a tad looser than ideal.
On my old one i ran 44/13 all the time and loved it. Great combo of punch and top speed for my driving style.
Should i just turn the music up and run this thing for a bit and let the rub between the cover and the spur go away the old fashioned way??
Wow that diff looks dirtier than it is when hit with a camera flash haha.
