Losi 1/8 8ight E 4wd Thread >
Old 07-03-2012, 09:22 AM
  #7726
dangerwr's Avatar
Originally Posted by Gene158 View Post
Hey I have a question for you guys. I actually have a 8ight T e 2.0 but I know the setup is very similar to the buggy. I just recently got it and I've noticed while driving it on the track that it makes a "chunky" noise when on the throttle. I know that's a crazy word to describe it but I don't know what else to call it. It's not coming from the gears, I think it's coming from the front driveshaft rubbing the chassis brace and radio tray but it's a little hard to tell. Has anyone else had this problem?
I have a Losi EP Truggy as well but have only experienced funky clunky noise on my buggy. Turned out to be a bearing on the outdrive of the rear diff--one of those flanged bearings. The bearing essentially came apart and the noise, I can only assume, was from the gears. Have you taken apart the front diff case and checked over everything?
dangerwr is offline
Old 07-03-2012, 06:05 PM
  #7727
chucko's Avatar
I have been running a 15 tooth with a 45 and I melted a few sper's. so I purchased a robinson 47 steel. in order to have the same gearing what pinion gear would be the same as far as the same gearing 17?
chucko is offline
Old 07-03-2012, 06:52 PM
  #7728
dangerwr's Avatar
Chucko I have always been told to go 1 on the pinion for every 2 on the spur. I have been told this by on-road guys (much finer pitch) but seems to be right. If I were challenged with the same problem I would use a 16t.
dangerwr is offline
Old 07-03-2012, 07:04 PM
  #7729
Gene158's Avatar
No I haven't taken anything apart but I guess it can't hurt to do so.
Gene158 is offline
Old 07-03-2012, 07:28 PM
  #7730
dangerwr's Avatar
It certainly would not! The Truggy takes a lot of abuse and needs a lot of maintenance . . .
dangerwr is offline
Old 07-03-2012, 09:10 PM
  #7731
Monteman's Avatar
Trader Rating: 16 (100%+)
Tekno kit help.
Didn't even realize that my NEU2200 can was only 40mm. The tekno V4 kit comes with the 42mm mount.
Stupid question of the day is, the 40mm V3 motor mount still bolts to the V4 chassis correct?
Monteman is offline
Old 07-03-2012, 09:13 PM
  #7732
tmo420's Avatar
I do believe it does. I can't wait for my kit to come in. Been on back order till early this month
tmo420 is offline
Old 07-03-2012, 11:13 PM
  #7733
Monteman's Avatar
Got a good chunk done tonight
Cant decide if i want to keep the blue towers or not. they look terrible against the tekno chassis but they match my body... I do have a set of TLR carbons on the way.
And i need to decide if i want to put the RX box on the other location or not.
Monteman is offline
Old 07-03-2012, 11:35 PM
  #7734
Trader Rating: 29 (100%+)
in no way trying to be rude, its simple math so 15/45 means that for every turn of the pinion the spur turns .333 turns so
15/45 = .333
15/47 = .319
16/47 = .340
16/48 = .333
that being said latley I've tried to run larger spurs with larger pinions as there is a greater tooth contact area and less chance to strip them or break
Al
akesj1 is offline
Old 07-03-2012, 11:40 PM
  #7735
had very similiar isse with 2 different truggies, one was rear diff other was front.
I can only assume the extra weight has a harsher affect on the drive train as our 8e buggy has had no issues in this area
Al
akesj1 is offline
Old 07-03-2012, 11:47 PM
  #7736
UN4RACING's Avatar
Trader Rating: 22 (100%+)
2 weeks I have been waiting. Should be here next week?????
UN4RACING is offline
Old 07-03-2012, 11:53 PM
  #7737
Monteman's Avatar
Can anyone confirm what center differential mount i need to work on the Tekno kit?
On the notes it says if you are converting the E use the nitro 4415 kit, but the 4420 is the E mount? Visually they look identical. Is there actually a difference?
I have a 4420 waiting at the LHS for me, just need to know if I'm gonna have to change that.
Monteman is offline
Old 07-04-2012, 09:36 AM
  #7738
8ight-e's Avatar
Trader Rating: 58 (100%+)
Could be, can you set it up on your stand and give it throttle and replicate? Do you know the sound the rear diff makes as it starts slipping and stripping? If it's the rear diff shim it quick and you maybe able to save it, if it's a bent shaft, best thing is to just replace it. Bent shafts do happen especially if you don't run a traktion drive or slipperential to help protect the drive line in a truggy. If it ends up being the rear diff, make sure you replace the ring and pinion gears in the diff.. mixing old and new never works well.
Originally Posted by blade329 View Post
I think ceramic is a waste of money on 1/8th scales. They don't seem to last any longer than the $1 one's that I normally buy. Go with Avid.
+1 avid and change more often and you will net better performance for less money and way less work. Think about it for the price of even lower end ceramics your at like $5each, you can spends the same amount with avid and have 5 full sets for the same price as 1 set.
8ight-e is offline
Old 07-04-2012, 09:39 AM
  #7739
8ight-e's Avatar
The E-kit top works with the tekno, but the rear center diff is the motor mount so you cannot use this unless you have both the plastic front and rear center diff braces. The nitro kit will get you the correct parts needed, but as I said you can get the top plate off the e-kit if you wanted it but it is not needed.
BTW Losa4420 is the 8ight 2.0 nitro part (updated parts) - this is fine and will work great and is better than the older 4415 kit as it doesn't need the extra bearing spacer.
8ight-e is offline
Old 07-04-2012, 09:40 AM
  #7740
Monteman's Avatar
Great, thanks for the help
Monteman is offline
