Losi 1/8 8ight E 4wd Thread
#7561
I recently bought a 8ight-e roller and when I did a camber check both the front and rear were at -6 caber. does anyone know the length of the turnbuckles when it is stock before I start to change the camber using the positions on the rear hubs. This is also with both hubs set in the center position.
#7562
You should be able to adjust the camber to what you want with the same tool that showed you it was at -6
#7563
#7564
Double Post, well now a triple post
#7565
anything new
#7566
I got the 10 degree carriers and inclined spindles in the mail today
. Did the steering mod to them...came out nice.
#7568
I am not sure what mod you need on the buggy but on the truggy I have learned about 3 things people often do:
1. Dremel the arms so the wheels do not rub (depends on brand of wheels)
2. Use the +2mm hubs
3. Switch the steering turnbuckle to the outside (flip the servo horn 180)
#7569
I haven't tried this yet because I find that I have plenty of steering on the tracks I run on.
Check out the mod here.
http://www.rctech.net/forum/nitro-of...ml#post7628649
#7573
So according to the spindles I have there does not seem to be any change that has occurred from a few years back to now.
#7575
I ordered them hoping to get the mentioned newer version that supposedly had more steering throw without any mods
Just didn't work out like that though
