Losi 1/8 8ight E 4wd Thread >
Old 05-09-2012, 04:31 PM
  #7396
Guest
Originally Posted by dangerwr View Post
Please make sure it is of the buggy though.
yes the buggy!!!!!! hahahahahahahah
LOSIRACER77 is offline
Old 05-09-2012, 05:20 PM
  #7397
dangerwr's Avatar
Originally Posted by scotty-j View Post
How deep does the rear center cvd go into the outdrive on the center diff on the e 2.0?
Mine is about half of the way into the center outdrive. You can shim it a bit too for better fit but do not use a 1.0 rear center CVD on a 2.0 chassis.
dangerwr is offline
Old 05-10-2012, 02:08 PM
  #7398
Guest
Default bodies
i want a cab forward body for my buggy!!!!!
Old 05-10-2012, 02:19 PM
  #7399
dangerwr's Avatar
New Danger shell attached.
Attached Thumbnails Losi 1/8 8ight E 4wd Thread-danger_shell.jpg
dangerwr is offline
Old 05-10-2012, 04:47 PM
  #7400
any ideas for more on power steering?
getloose is offline
Old 05-10-2012, 06:30 PM
  #7401
Guest
bigger sway bar- 2.5
Old 05-10-2012, 06:31 PM
  #7402
Guest
sexy!!!!!!! hahahahaha
Old 05-10-2012, 07:06 PM
  #7403
Guest
hey man i burned up a charger the other night? so what do u use, and a iron?
i had a icharger 106b, i need another 1-10 amp charger. then my soldering iron has had it, its 12yrs old ungar)
Old 05-10-2012, 07:54 PM
  #7404
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
decrease front droop.
thicker front diff oil.
thinner center diff oil.
SEF is offline
Old 05-10-2012, 08:14 PM
  #7405
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Hi, I'm going to look at a used 8ight E roller chassis tommorow. Anything I should look out for in particular. He offered to replace anything that looked worn out. Also any major problems with 8ight platform? Everybody I know that runs one (90% of my track) has not mentioned any issues with their buggy.
Want to be prepared before i buy. Thanks.
Rockthecatbox21 is offline
Old 05-10-2012, 08:18 PM
  #7406
Guest
which buggy r u looking at
Old 05-10-2012, 08:25 PM
  #7407
Pretty sure it's an 8ight E 2.0
Old 05-10-2012, 08:29 PM
  #7408
Guest
which one r u looking at so maybe we can see something u cant, thats all
Old 05-10-2012, 08:32 PM
  #7409
Sorry I got confused, it's a local guy at my track and i'm going to see it in person. He doesn't have it listed online. Just wondering what key areas i should look at and which places i should look for broken parts and/or wear.
Old 05-10-2012, 08:36 PM
  #7410
Guest
any drive shafts and the shock mounts, and diff out drives look at the bearings
