Losi 1/8 8ight E 4wd Thread >
Old 03-27-2012, 05:58 AM
  #7096
Trader Rating: 25 (100%+)
I've decided to convert my 8ight 1.0 over to electric after it sitting on the shelf the last 3 yrs. E-scale has taken off at my track and I thought I'd jump on the wagon. So I'm looking for a set up. Didn't know if the Drake setup on TLR's site it's still a good one. Any help, tips would be great.
Mitten is offline
Old 03-27-2012, 08:22 AM
  #7097
bjanzen's Avatar
I am a Castle guy but my race buddy just got a Eight 2.0..... It came with a Tekin system in it...... 2050kv we think.
Question is this...... I know nothing about hotwire settings to help him with...... Can someone give me a basic setting??? We run a fast smooth track.....
bjanzen is offline
Old 03-27-2012, 11:11 AM
  #7098
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Tons of setups here:
http://www.teamtekin.com/hotwire/ESC...up-sheets.html
SEF is offline
Old 03-27-2012, 11:13 AM
  #7099
SEF
SEF's Avatar
I recently converted my 2.0 to electric and love it
I used something very close to Drake's setup with inclined spindles for nitro and kept the same setup for electric and it was dialed
SEF is offline
Old 03-27-2012, 11:18 AM
  #7100
bjanzen's Avatar
Originally Posted by SEF View Post
Perfect! Thanks for the help
:-D
Question is this..... The "timing " was set at 80 when we got the buggy. We changed it to 40 and the second run de-soldered the connection! Went back and changed to 80 on the timing and set current limit at 75..... Ran fine with no problems. Any suggestions?
bjanzen is offline
Old 03-27-2012, 03:34 PM
  #7101
Thanks SEF. Are the inclined spindles only available in aluminum? Or am I missing something?
Mitten is offline
Old 03-27-2012, 04:04 PM
  #7102
Trader Rating: 72 (100%+)
Yes, only in aluminium and you have to change them as a set with the uprights.
patrick is offline
Old 03-27-2012, 04:17 PM
  #7103
Thanks, At $90 I think I will have to live without them for a while. I meant to ask before, Anyone know it the Pro-line bulldog body will work.
Mitten is offline
Old 03-27-2012, 05:37 PM
  #7104
SEF
SEF's Avatar
Not enough room for a 4s lipo. If it is not cut yet, you might be able to make it work and cut the sides long. The body will not sit correctly. It will interfere with the battery.
Same goes for jconcepts body and the Losi 2.0 EU body.
SEF is offline
Old 03-27-2012, 09:46 PM
  #7105
Guest
I use the jconcepts body for the losi 8ight or the stock body with venom lipos
LOSIRACER77 is offline
Old 03-29-2012, 09:21 PM
  #7106
Monteman's Avatar
Trader Rating: 16 (100%+)
How much wiggle is normal in the spindles/carriers front and rear on these guys?
Monteman is offline
Old 03-29-2012, 09:23 PM
  #7107
dangerwr's Avatar
You want wiggle with the Losi. So I say all the wiggle! Just make sure nothing is seriously worn . . .
dangerwr is offline
Old 03-29-2012, 09:27 PM
  #7108
Monteman's Avatar
cool, still have the plastic bits so wear will be obvious once i take them apart.
spend so much time trying to get the wheel wobble out of my Revo's just wanted to make sure lol
Monteman is offline
Old 03-29-2012, 09:40 PM
  #7109
dangerwr's Avatar
Yeah, I share the same opinion as many--the Losi gets better with wear. Just be smart and learn to identify when things are ready to let loose with excessive wear.
dangerwr is offline
Old 03-29-2012, 09:44 PM
  #7110
Monteman's Avatar
Bought one used, i have ran it so far for a total of 20 minutes. Didn't know if i was in for a replacement or not, just wanted an opinion from others.
The wiggle after putting the tires back on caught me off guard.
Monteman is offline
