Losi 1/8 8ight E 4wd Thread >
Old 03-01-2012, 06:35 PM
  #6991
KingdomRacer's Avatar
Those springs are off IMO. The stiffest I go is greens in front and blacks in rear.
And next is the ride height is off too IMO. I never go more than 30mm in the rear and 28mm in the front.
KingdomRacer is offline
Old 03-01-2012, 08:11 PM
  #6992
Monteman's Avatar
Trader Rating: 16 (100%+)
How many different chassis options are there? The pics i received of my soon to be 8ight 2.0 is black, amain shows it gold(ish) the truggy 2.0 looks pink, ebay has them in blue? I'm confused.
What chassis can i use as a replacement if i need too on my 8ight 2.0 converted to Electric buggy?
As long as its a 2.0 buggy pick your color and run with it? or are there preferred chassis pro's and cons of different ones available?
the ones listed above are ones i have seen repped as stock chassis, not even counting the FlexTech or Fioroni options.
Monteman is offline
Old 03-01-2012, 08:34 PM
  #6993
Bfschoff31's Avatar
TEKNO RC!!!! Best electric conversion kit for Losi ever built. Absolutely bulletproof, distributes the chassis weight better. Def worth the $$$. Its what i got!
Bfschoff31 is offline
Old 03-01-2012, 08:43 PM
  #6994
Monteman's Avatar
I was thinking about the Tekno kit as an option, but this one is converted already with the Losi conversion kit i believe. Here's a couple pics of what i have coming. Not going to buy a new chassis till it arrives of course, hard to tell by the pics, doesn't look too bad at all. But knowing me i will replace the chassis, if for nothing else im like that...
Monteman is offline
Old 03-01-2012, 10:20 PM
  #6995
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by neobart View Post
IMO with that battery floating on top, it's just an accident waiting to happen.
No it's not. Have ran it for a good while and it's secured well. On top of the straps holding it in place it's also 3m double sided taped between the two. It's going no where at all
Mr.juarez is offline
Old 03-03-2012, 02:43 PM
  #6996
dangerwr's Avatar
Default Titanium hinge and aluminum hub?
Anybody have any experience with titanium hinge pins with aluminum hubs? I tried this a few years back and the titanium hinge pins chewed up the aluminum hubs. Has anyone else ever experience this issue? It makes sense due to their differences in hardness.
dangerwr is offline
Old 03-06-2012, 10:41 AM
  #6997
did you use ti-prep or another type of anti seize compound?
titanium and aluminum will bond together over time if you dont.
getloose is offline
Old 03-06-2012, 01:49 PM
  #6998
Suspended
Trader Rating: 8 (83%+)
Looking to get more rotation out of the rear, it has an off power push in low speed corners. What are some things I can do to help get some rear rotation?
TheBoot is offline
Old 03-06-2012, 03:32 PM
  #6999
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
What type of track surface? And what are the fast tires to use?
I had similar issues and the best thing I did was use the 10deg inclined spindles and carriers, along with 5/5/2 in the diffs.
SEF is offline
Old 03-06-2012, 04:28 PM
  #7000
bjanzen's Avatar
Give us more info...... What diff oils? What tires? What track type? Springs? Camber settings???? Toe amount? Ride height?
My guess would be camber or diff lube.........
bjanzen is offline
Old 03-06-2012, 05:33 PM
  #7001
do any of you have any smart diff springs? I have TONS of off power steering and Tons of on power understeer. I need to balance the two out a bit.
getloose is offline
Old 03-06-2012, 05:39 PM
  #7002
dangerwr's Avatar
Are you asking if somebody has spare springs or if anyone is running the Smart Diff?
dangerwr is offline
Old 03-06-2012, 06:19 PM
  #7003
spare springs. I only have the set thats in there which are the ones that make it extremely aggressive off power steering and mellow on power.
i need some more options and a brand new set is absurdly expensive.
getloose is offline
Old 03-06-2012, 06:57 PM
  #7004
dangerwr's Avatar
Gotcha. I have some but do not know what I have off hand. Any idea as to what spring rate you are looking to use?
dangerwr is offline
Old 03-06-2012, 09:14 PM
  #7005
Monteman's Avatar
Quite impressed with this out of the box. Cant wait to start tearing stuff up
Monteman is offline
