Losi 1/8 8ight E 4wd Thread >
Old 12-26-2011, 11:22 AM
  #6766
rcguy76559's Avatar
Trader Rating: 22 (100%+)
Originally Posted by lethal19 View Post
I have the Mamba Monster I have not run it much because the BEC I have the wires are now to short to wire in and I was unsure if I should wire it in or not
you should be ok with the mmm i was running savox 1233 its a power hog. i never had any problems. I also run a glitch buster on rx.
rcguy76559 is offline
Old 12-29-2011, 10:33 AM
  #6767
scracer68's Avatar
I bought a used 8ight e, it has a castle 1800kv motor with a 48 spur and 15 pinion. How much larger can I go on the pinion without overheating the motor? I'd like more top end but I don't know the gearing range on the 8ight e. Thanks for any help you can offer.
scracer68 is offline
Old 12-29-2011, 10:47 AM
  #6768
losi_racer's Avatar
Trader Rating: 25 (100%+)
It's going to depend on outside temp as well as the size of the track . Just run for 4-5 min . Come in and temp the motor , you wanna keep it under 180 , here in az it was about 105 ambient temp and with a 15 pinion on my 1900 I was at 155
losi_racer is offline
Old 12-29-2011, 12:23 PM
  #6769
have a chance to get a eight 2.0e for cheap that was wrecked really hard. my question is can you upgrade the car with the tekno v4 kit, or would it all have to be done with losi products. car will need a new chassis and some other stuff for sure, just wondering what my options are should i chosse to buy it
lance.d is offline
Old 12-29-2011, 10:26 PM
  #6770
Integra's Avatar
Your 3 teeth Off on the Spur, You need to be running 45/15 which is what 99.9% of the guys run with a standard 1900Kv or similar.
Integra is offline
Old 12-31-2011, 02:58 AM
  #6771
Whilst on the subject of gearing, am I about right on 46t spur, 13t pinion on a 2250kv on 4s??
I have a 11,12t pinion in my box too if needs be.......
Headling is offline
Old 12-31-2011, 11:11 AM
  #6772
quick question, is anyone has the spring rate chart for the front spring, thanks
http://www.amainhobbies.com/product_...ing-Set-6-Pair
mwhiteknight is offline
Old 01-02-2012, 09:18 AM
  #6773
rcguy76559's Avatar
i'm running 14
Old 01-02-2012, 09:57 AM
  #6774
rcguy76559's Avatar
i been searching for this with no luck. ackerman - short vs long which one has more off power steering low speed? I was trying to figure out which way the inside wheel has more angle?
Old 01-02-2012, 01:48 PM
  #6775
Trader Rating: 26 (100%+)
I have the same motor and MMM esc and I run at 46/16 at 85-90% throttle on a large 1/8 outdoor. I would just keep the 15 pinion and go down to stock gearing which is 45/15..
n2trouble is offline
Old 01-03-2012, 01:35 PM
  #6776
Suspended
Trader Rating: 440 (99%+)
nm
MattP is offline
Old 01-04-2012, 12:42 PM
  #6777
dangerwr's Avatar
Hope this helps!
Ackermann
More
(Bigger difference in steering angle between the two font wheels)
More Ackermann makes the steering more consistent, and smoother.
It just feels right, also at low speeds and in tight turns.
Less
(Smaller, or no difference in steering angle between the two font wheels) Less Ackermann makes the steering more agressive at high speeds.
The car turns in more agressively.
It doesn't work well when either traction or cornering speeds are low.
dangerwr is offline
Old 01-07-2012, 10:49 AM
  #6778
Hey guys. I'm picking up an 8ight E 1.0 in a trade and was wondering what the differences are between the 1.0 and the 2.0. What are things to lookout for when I get it? What spares do I need? Do the 2.0 parts bolt on? Thanks in advance.
Mototech is offline
Old 01-08-2012, 11:08 AM
  #6779
Bugger234's Avatar
Recently I bought a Losi 8ight E 2.0 and was taking apart the diffs and everything to put in new bearings which needed to be replaced. After putting the gears in the diffs, I tried putting the case back on, but whenever pressure is on the bearing inserts, or on the diff at all (Like when you screw on the control arm pin holders) the diff pinion and the diff gears lock up and don't to move. I was wondering if this was a problem with the case, or a problem with the gears. I've already tried shimming it in a multitude of different ways.
Also, if I'm running a Tekin 1700kv T8 with a 48tooth center diff. What pinion should I use to keep temps low but keep enough power? I know it needs to be low, like lower than 15.
Any suggestions help! Thanks!
Bugger234 is offline
Old 01-08-2012, 11:15 AM
  #6780
Super Moderator
Funkymojo's Avatar
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 76 (100%+)
Hi Guys, i've got a question to ask. If i'm using a 46t spur gear with a 1750kv-1800kv with 4s lipo. What pinion gear would you guys recommend? The track is medium sized, pretty technical with a couple of straights. Thanks guys
Funkymojo is offline
