Losi 1/8 8ight E 4wd Thread >
Old 11-30-2011, 07:28 PM
  #6706
dangerwr's Avatar
Originally Posted by Solidd33 View Post
Losi spring rate question:
Personally, in using black vs green springs the black feel softer. I looked around and it appears that the black springs 3.4 are supposed to be stiffer than the green 3.1. Is this true?
I understand the same thing. The thing is when I used the green rears I used 25W fluid. With the black springs I use 30W oil. I would not say the black springs actually seemed softer but when working together with thicker fluid the car handled a bit better.
dangerwr is offline
Old 12-02-2011, 02:16 AM
  #6707
Solidd33's Avatar
Trader Rating: 26 (100%+)
Continuing with suspension questions:
At a race ready 7.9lbs my silver front springs(running 40wt AE oil w/50% rebound) have to be bottomed out just to achieve 28mm ride height. Is this normal and/or would it just make more sense to up the spring rate? (green)
Solidd33 is offline
Old 12-02-2011, 02:42 AM
  #6708
Gilly2011's Avatar
my losi running a tekin rx8 with tekin t8 1900kv motor proline slipstream body airtronics m11 2.4ghz with heaps of after market stuff this car is awsome
Gilly2011 is offline
Old 12-02-2011, 02:45 AM
  #6709
Gilly2011's Avatar
pics
Attached Thumbnails Losi 1/8 8ight E 4wd Thread-img_0538.jpg
Old 12-02-2011, 07:49 AM
  #6710
dangerwr's Avatar
You could try full rebound and see how it works for you. And as you mentioned, your other option is to try the stiffer spring. I had this problem before with the Losi silvers--bought fresh springs and problem solved!
dangerwr is offline
Old 12-02-2011, 09:37 AM
  #6711
KingdomRacer's Avatar
I have found that large open fast tracks work better for me with the greens up front but on smaller, tighter tracks the silvers up front and greens in the rear work better with 40f/27.5r oil wt.
When I go with the greens up front I also may step up the oil wt. to 45wt (depends).
This is what works for me and I'm sure may not work for others, you always have to find what works for you.
And like stated above I felt full rebound does help with the silvers up front but still use the greens for big tracks.
KingdomRacer is offline
Old 12-03-2011, 09:27 PM
  #6712
Solidd33's Avatar
These sound like good tips. I appreciate the info guys and will continue to experiment.
Solidd33 is offline
Old 12-04-2011, 12:47 AM
  #6713
DBL15's Avatar
well about 4 or 5 full race days in and my 8ight is getting better and better , its freeing up nicely , its time to adjust everything as its all settled real nice
real happy no broken parts and near real wear and tear
DBL15 is offline
Old 12-04-2011, 09:17 AM
  #6714
dangerwr's Avatar
+1. I am gonna try greens up front on our large tracks next year and see how I like it . . .
dangerwr is offline
Old 12-04-2011, 02:53 PM
  #6715
DBL15's Avatar
so is that greens front and rear on larger tracks ?
DBL15 is offline
Old 12-04-2011, 03:06 PM
  #6716
I use the black springs in the rear for larger tracks with greens up front.
Old 12-04-2011, 03:25 PM
  #6717
DBL15's Avatar
thanks mate will check what i have in my supply
what shock oils you running ? front / rear
DBL15 is offline
Old 12-04-2011, 03:43 PM
  #6718
30-32.5wt rear/ 42.5-45wt front
The heavy side is for when it gets above 90*F
Old 12-04-2011, 06:01 PM
  #6719
DBL15's Avatar
anyone know what the race roller weights it comes with as i have not changed anything yet and i like how it handles but yeh just wondering what oils would be in it
i am at work so i cant check the book
DBL15 is offline
Old 12-05-2011, 01:13 PM
  #6720
Solidd33's Avatar
Track Setup Advice
If moving to silver rears rather than stepping down oil weight, will this still create a similar effect at improving traction? I imagine based on how much softer the suspension feels that it would indeed, albeit to a lesser degree.
Drake setup except for below changes
7.9lbs race weight w/4s lipo
-1 camber f/r & 4deg total toe-out front
40f/35r silver/black, on small tight track, slightly damp but blue grooved clay
27f/28r ride height
The rear of the car liked to get loose around corners even at slow speeds using ultra-soft Sweep Exagons.
Take this for what you will with setting up for your own track conditions everyone.
Solidd33 is offline
