Losi 1/8 8ight E 4wd Thread >
Old 09-19-2011, 05:30 PM
  #6481
Trader Rating: 127 (100%+)
Originally Posted by krash'um View Post
Ran my 8ight 2.0 with Losi econversion for the first time today and it performed great as expected I run a RX8/T8 1900kv, 4s with a 15 pinion, the only concern I have is it consistently temped at 188* after 10 mins? With this resolved and some minor suspension tweeks it'll be ready to compete. How are you guys managing temps?
timing is down to 1 (the lowest setting)
current limiter is at 60%
Are you sure your temp gun is accurate? Temps in nitro seem to be taken with grain of salt, but the E guys never seem to question their readings...
Ei8ht is offline
Old 09-19-2011, 05:38 PM
  #6482
Integra's Avatar
A Clean Temp gun is an Accurate temp gun. Nitro guys and there Dirty pit bags n such can be problematic if you dont maintain the All seeing Eye on your gun.
Integra is offline
Old 09-19-2011, 11:09 PM
  #6483
Trader Rating: 78 (100%+)
Default losi8T
I have been running my 8T with the 1350 tekin motor, and 6s, with the controller backed down to 6* and med area for punch. am going to try the 10,000 in center diff, because I'm ballooning the front tires on the front straight, but it's exciting,LOL the front straight at the track I've been running is pretty long with small step jumps. If your in front of me when we start down the straight, you'll be covered by dirt and behind, OMG the best part is the motor hasn't come off the track at more then 150 and I've had to take power out of it, to keep myself from hurting myself. really like the 6s combo, with the low kv motor. I have a emaxx with a 4s system in it and it is quick and capable of 45mph and this thing goes by like the emaxx sets anchor on the straight. even has enough to stay with my brothers 8 port buggy(bad fast). I finally got something that keeps up and I can drive YAH.
btrukr is offline
Old 09-20-2011, 12:26 AM
  #6484
That is a good point. Still strange though as I have two temp guns and my buddy has one. All three side by side with clean lenses read with in a degree of each other under 100*. Above 100* there can be a 10-15* difference.
Above 200* there can be a 20* difference
Around 280* our temp guns have readings of at around a 30* difference!
Ive even played with the emissivity settings and it's still tough to know whats right.
Tekin recommends people to put a piece of black electrical tape on the motor for more accurate readings:
Originally Posted by http://teamtekin.com/blmotortips.html
All Motors, including Tekin Motors, tend to lose strength in the magnet at high temperatures. When the magnet loses strength it shows up as a loss of speed. Monitor your motor temp with a temp gun, place a small piece of black tape on the aluminum can to improve accuracy of the readings.
Ei8ht is offline
Old 09-20-2011, 03:30 AM
  #6485
krash'um's Avatar
Originally Posted by DBL15 View Post
hmmm to me there is another problem or something not spinning freely mate
can you turn your pinon easy with your fingers ? its not hitting the motor mount is it?
i run the same set up in hotter conditions in Australia and after 15 min my motor only comes off at 150 to 160
whats your current limiter set at as wheel spin create heat
Current limiter is at 60% everything spins freely, I'll double check my temp gun for accuracy. Now I'm kinda thinking of going to a 1400kv with 6s.
krash'um is offline
Old 09-20-2011, 09:08 AM
  #6486
Im about to convert my 8 to an 8 e and just looking at some budget electronics to get me going.
I was thinking about the Hobbywing SC8 ESC and a 1800kv leopard 4 pole motor.
What do you think?? I dont have the money for a tekin/Castle:
Here are links:
Motor:
http://www.ebay.co.uk/itm/2508627265...84.m1423.l2649
ESC:
http://www.ebay.co.uk/itm/2806300367...84.m1423.l2649
Headling is offline
Old 09-20-2011, 09:49 AM
  #6487
Trader Rating: 29 (100%+)
Here are links:
Motor:
ESC:
The Motor and ESC are by far the most important part of the Electric Model.....
Cheap electronics mean down time and result in a regretable purchase!, also I'd never consider buying a used electric with that set up.
Castle or Tekin are reputable set ups , save or borrow the money for it. New is the best route.
Al
akesj1 is offline
Old 09-20-2011, 09:53 AM
  #6488
brian015's Avatar
Here are links:
Motor:
ESC:
I don't race but I've had good luck with a leopard motor in my buggy. The one you link to is too small, though. You want a 4065 to run in a 1/8 buggy.
I'd also go for a bigger HW esc. I'd get one that was 6s capable - not because I would run 6s in a buggy, but because it should be more reliable on 4s.
brian015 is offline
Old 09-20-2011, 02:15 PM
  #6489
krash'um's Avatar
Great info guys thanks, I appreciate it.
krash'um is offline
Old 09-20-2011, 02:23 PM
  #6490
Numburn's Avatar
Newbie here
I am looking to get my first 1/8 buggy and am leaning towards the 8ight-E 2.0. Can anyone give me any tips on what to look for in a used one? Certain worn parts or such?
Also, what are important parts to pick up?
Numburn is offline
Old 09-20-2011, 02:26 PM
  #6491
Integra's Avatar
Originally Posted by Numburn View Post
Newbie here
I would honestly suggest going new if your not too sure on the wear items your looking for. Some thing's are more of a Feel thing vs just being able to look at the part and tell if its worn out. Are you buying from a Trusted Local or Looking online ?
Integra is offline
Old 09-20-2011, 02:56 PM
  #6492
Numburn's Avatar
It would probably be online. I'd definitely prefer to buy a new one but used they seem to be going for about $250 vs $600 new. I'm still trying to weigh whether it is worth buying used and replacing anything worn.
Numburn is offline
Old 09-20-2011, 03:17 PM
  #6493
rustyfingers's Avatar
D.Quick has a Losi 8 2.0 for 150. Pick up the conversion for 75 and you have a nice ebuggy for around 225. I have a 8e body you can use (it's not a POS) and you could probably get 30+ for the nitro parts pretty easy. Don't remember what upgrades he has but the buggy is in very good condition. He's had it for sale for a while so you might be able to get it a little cheaper.
Also, M.Harrison from LA had one for sale for 300 with only a couple of races on it. Check with Bubba, it might still be available.
Hell, if you would have been there Sat. night I probably would have sold you mine for 10 bucks. Never been so frustrated in my life. Nothing wrong with the car but that last double before the quad was KILLING ME...
Dennis
rustyfingers is offline
Old 09-20-2011, 03:32 PM
  #6494
DBL15's Avatar
yeh buy new for sure these things are fast and can have big crashes , atleast if new you know what you have done to it and how many times you crashed big and what parts need doing etc
DBL15 is offline
Old 09-20-2011, 05:45 PM
  #6495
Trader Rating: 50 (98%+)
Kevin It is always better to buy new. If you but a used car one persons like new could be another persons worn out. If you were to buy used I would sugest to only get something you can see or from someone you know. Most of the time you will wind up paying more for replacement parts on a used car then you will be at the price of a new one from the get go.
See yall up there for charge em up. By the way new layout looks sick.
micrors4guy is offline
