Losi 1/8 8ight E 4wd Thread >
Old 09-01-2011, 10:42 PM
  #6331
Slash and Burn's Avatar
Trader Rating: 24 (100%+)
Originally Posted by krash'um View Post
Hey Guys, I'm a newbie to 8th scale electric and I have a Losi 8ight 2.0 that I just ordered the Losi e conversion. My questions are, 1. Does the Losi 8ight 2.0 and 8ight e share the same chassis and suspension components? and 2. I will be running the Tekin RX8, T8 1900 kv buggy motor with a 4s battery, will the nitro body fit or will I need the e body? Thanks for the help.
All the components are the same except for the E conversion components, the E and the nitro are the same vehicle. You will need an E body, mostly for battery clearance. The Losi E body has laser cut vent holes, very cool!
Slash and Burn is offline
Old 09-02-2011, 01:58 PM
  #6332
Trader Rating: 26 (100%+)
1. Yes same chassis as long as your nitro isnt the RTR model.
2. Get the Proline Slip Stream body for the most battery clearance.
n2trouble is offline
Old 09-02-2011, 02:22 PM
  #6333
krash'um's Avatar
Originally Posted by n2trouble View Post
1. Yes same chassis as long as your nitro isnt the RTR model. I have the race roller.
Thanks for the info guys, I sent in my RX8 to be uptdated can't wait to get it back and "e" go racing.
krash'um is offline
Old 09-02-2011, 02:45 PM
  #6334
neobart's Avatar
I'd say get the Losi body for longevity. The Proline body is weak as spaghetti.
neobart is offline
Old 09-02-2011, 03:40 PM
  #6335
Is it true that Jconcepts makes the Losi body?
Old 09-02-2011, 04:19 PM
  #6336
dangerwr's Avatar
Yes, they make an Illuzion body for the 8ight-E . . .
dangerwr is offline
Old 09-02-2011, 04:20 PM
  #6337
Casper's Avatar
Trader Rating: 34 (100%+)
JC makes bodies for the 8ight series but the Losi/TLR kit bodies are made by Losi/TLR.
Casper is offline
Old 09-02-2011, 08:31 PM
  #6338
krash'um's Avatar
Ended up ordering the Losi body primarily for durability. I know that the "e" is a little heavier than the nitro and I will download the setup sheet for it but for now would it be safe to start 5wt heavier on the shock fluids?
krash'um is offline
Old 09-02-2011, 09:14 PM
  #6339
Integra's Avatar
Stock weight buggy
2.5wt to start out with and get some Black spring's for the rear.
Integra is offline
Old 09-02-2011, 09:40 PM
  #6340
krash'um's Avatar
Originally Posted by Integra View Post
Stock weight buggy
black springs in the rear... which springs do you run in the front?
krash'um is offline
Old 09-02-2011, 11:42 PM
  #6341
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Silvers up front. Since I'm running the lrc rear links, I'm gonna try out this combo this weekend.
Green rear springs, 54 piston, 30 weight oil.
Silver front springs, 54 piston, 40 weight oil.
Diffs are 5-5-2.
12* inclined spindles and carriers.
Track is very dusty, tight, and technical.
nickdawg18 is offline
Old 09-03-2011, 08:33 AM
  #6342
dangerwr's Avatar
Words. I really like a center Smart Diff (SD) on a tight, dusty & technical track. Just something to think about in the future . . .
dangerwr is offline
Old 09-03-2011, 09:56 AM
  #6343
nickdawg18's Avatar
I know that they've been out for awhile but what exactly does a smart diff do?? Do you still use diff fluid?
Old 09-03-2011, 10:55 AM
  #6344
tasi's Avatar
http://www.tlracing.com/Products/Def...rodId=LOSA3601
tasi is offline
Old 09-03-2011, 09:37 PM
  #6345
frazz's Avatar
Just getting back into racing after several years away from the hobby. Picked up an 8ight, first time with 1/8 scale, can't see how I could go wrong with the Losi buggy
Just had a question on the conversion kits, this is a nitro buggy, and I would like to go directly to a Tekno V4, would I still need the losi conversion kit, and to anyone is running the Tekno, should I be ordering anything else to go with my E conversion?
My plan is also to go RX8, T8-1900, 4S for electrics, after reading and catching up on this thread that seems to be the way to go, thanks for all the great info btw
frazz is offline
