Losi 1/8 8ight E 4wd Thread >
Old 07-30-2011, 03:22 PM
  #6121
jrxt's Avatar
20/45 on 5ooo 4S Gens Ace outdoor 80%EP 20 mins easy stay out of the break as it creates heat!
jrxt is offline
Old 07-31-2011, 12:37 PM
  #6122
Anyone have any tricks to get the 8ight e 2.0 body to fit over a venom 35c 4s battery? Im having issues with the battery hitting on the body.
barry1me is offline
Old 07-31-2011, 05:09 PM
  #6123
Integra's Avatar
Originally Posted by losi_racer View Post
3. sold the 22, not its just bug, trug,and pro 4.
nick what do you run motor wise???
Werks as of late, But Neals on a New Nova/OS fancy right now So im sure ill end up with something along those lines.
Wait are we talkin SC or 1/8 lol
4S FTW lol
If i can do 15 ill be fine, i wont be shooting for 20
X2 4S 5000mah is where its at for buggy, Truggy well that's a whole different animal.
Integra is offline
  #6124
Integra's Avatar
20/45......Is that a Typo ?
Integra is offline
Old 07-31-2011, 11:02 PM
  #6125
losi_racer's Avatar
Trader Rating: 25 (100%+)
LOL i ment the 1/8th electric motor, i didnt say engine
everything now is 100% ordered, now just waiting
losi_racer is offline
Old 08-01-2011, 08:24 AM
  #6126
jwemail's Avatar
hi guys, i just got my first losi 8-e and love it. i had a ? though i currently am running a rx8 and t-8 2650 in my buggy, from what ive read so far is that 3s will pair up nicely with the 2650, and 4s is to much unless you tone everything down, but would a gens ace 3s 5000mah 40c last 20 min, or will i need to tame down the gens ace 4s 5000mah 40c in order to make a 20 main. i was running that power system in my losi scte with maxamps 2s 6500mah 150c, and i was getting 20 min on a small tight and tech track. i was also concerned on the weight of the 4s and overheating the motor. thanks guys for the advice in advance.
jwemail is offline
Old 08-01-2011, 08:39 AM
  #6127
Hey,
Been into the 1/8 scale now for a few months. Got myself to start with the losi 8ight 2.0 RTR and after trials, errors and scored pistons I have decided to move to electric.
I just finish building my 8ight 2.0 EU roller and just ordered myself the losi conversion kit, hiteh high voltage servo, the MMM COMBO 2200 and have NOT bought the lipo's yet. I'm not into track racing as I'm more into speed drags and jump bashing.
Since I'm new to electric and I have a few questions I wanna ask.
1. For speed what would be the best gearing?
2. Would you use Metal or plastic gears?
3. I'm still not understanding the difference in all the lipo battery terminology. Could some one explain in my set up what lipo I would use??
That's all I could think of for now... Ill Think of more later
Gaspare is offline
Old 08-01-2011, 11:14 PM
  #6128
after going to the adam drake suspension setup it helped the handling quite abit. One question though is how do I get more steering? Im used to my SC10 4x4 with tons of steering and I want to set it up like that. Any suggestions on what I can do to get more steering?
barry1me is offline
Old 08-02-2011, 08:15 AM
  #6129
Thumbs up
I have the same battery. However I am currently running a 3S set up. I was planning on using a heat gun to heat the body up. then form it over the battery. Last time i ran my 4S w/ the stock body w/o heating and molding, it broke the nose off and I ended up just using velcro which works just fine. No Pro here but I hope it helps. Some of the other guys may have beter solutions.
bsloan22 is offline
Old 08-02-2011, 08:57 AM
  #6130
R/C Tech Elite Member
blade329's Avatar
Trader Rating: 114 (100%+)
You're never going to get that kind of steering out of an 1/8th scale buggy.
There are lots of ways to improve the steering. You can remove the front sway bar. Use lighter fluid in front and use less rebound. If using the aluminum inline spindles/carriers, you can remove grind some material (about 2mm) off the spindles to allow more turning. It's a common upgrade that the Losi drivers make. Last week I had my 8ight turning real sharp (on par with an RC8Be), with no sway bar and lighter fluid up front, but it came at the cost of less rear traction.
blade329 is offline
Old 08-02-2011, 10:56 AM
  #6131
Akhor's Avatar
My 8E 2.0 always seems to jump nose high.. I've even moved the battery as far forward as I can..
Any suggestions to get this more level?
Akhor is offline
Old 08-02-2011, 11:10 AM
  #6132
blade329's Avatar
Check the ride height. What weight of shock fluid are using f/r? This buggy seems to fly better with thicker fluid in the front. I noticed that an over powered buggy that's not getting enough traction will also jump nose high. The jumps themselves can also be the culprit.
blade329 is offline
Old 08-02-2011, 11:46 AM
  #6133
Akhor's Avatar
35wt f and r.. White springs all around.
I'll try upping the front weight! Thanks!
Akhor is offline
Old 08-02-2011, 11:48 AM
  #6134
jwemail's Avatar
any help on my issue before i pull the trigger on lipos and have to learn the hard way. am i asking in the wrong thread.
jwemail is offline
Old 08-02-2011, 11:55 AM
  #6135
blade329's Avatar
I'm running 40wt front and 30wt rear. Silver springs up front, Black on rear. Stock ride height. I race at a large outdoor track with a loamy surface.
blade329 is offline
