Losi 1/8 8ight E 4wd Thread >
Old 04-23-2011, 08:04 AM
  #5806
Integra's Avatar
Originally Posted by Bman's 3XNT View Post
How does everyone check their camber? If I set mine up using plates (-2)then recheck when I install my tires it always seems to be different(0,-1). So which reading is more accurate? Thanks........
I personally use My Hudy station to get me squared up. (everything even from side to side) Then ill try and use a set of tires I plan on racing with and make sure im in the ball park of where i would like to be with a plain Jane RPM monster camber gauge.
Integra is offline
Old 04-23-2011, 08:05 AM
  #5807
Integra's Avatar
Originally Posted by iThinman View Post
Is there a 48t plastic spur gear available for this car?
No.
Integra is offline
Old 04-23-2011, 08:06 AM
  #5808
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by orgnoi1 View Post
Hey guys I have a very quick specific question...
I have a buddy who just got the 8ightE... he ordered the wrong motor combo (the 2650kv)... I realize that its WAY over sized in motor... but could he get away with a 12t or 13t pinion on stock spur gearing and keep both the heat down and speeds consistant with the stock gearing on say a 1900kv?
Thanks!
just run a 3s lipo config.. Really shouldn't be an issue
8ight-e is offline
Old 04-23-2011, 01:26 PM
  #5809
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
So do you find a difference between your setup station and a particular set of tires? Mine always seems to change.
Bman's 3XNT is offline
Old 04-23-2011, 08:06 PM
  #5810
Integra's Avatar
It changes...Dont ask me why , But in the end i go of what is Physically in front of me, The Station as i said is for ensuring your equal side to side.
Integra is offline
Old 04-24-2011, 03:45 AM
  #5811
orgnoi1's Avatar
Trader Rating: 39 (100%+)
Thanks guys for the responses on the 2650 motor question... I am removing my subscription to the thread since I dont own the 8ight myself... but just wanted to say thanks!
orgnoi1 is offline
Old 04-24-2011, 01:39 PM
  #5812
Does anyone use Fioroni parts on their 8ight-e's? Mine needs a new chassis and front shock tower, and the Fioroni stuff has caught my eye.
Matt
Matt_N is offline
Old 04-24-2011, 01:50 PM
  #5813
dangerwr's Avatar
Matt
I do actually! I use their rear chassis brace. I was also considering their front shock tower brace since I am a little too rough on the stocker. I ultimately went with King Headz for a couple reasons. The Fioroni have two versions of the shock towers--one for EU and one to mimic stock 2.0. I do not need the EU setup and their stock 2.0 replacement had the "B" hole for the camber link offset. Probably not a big deal but did not want to find out. Fioroni is also quite a bit pricey here in the states and King Headz is a trusted brand IMO so just went with them.
I talked with Fioroni-USA regarding the chassis and was told it is "good." Most complaints are that the width is different so is difficult to mate some of your standard bodies. This is why I went with a BCE. Hope this helps . . .
I also was going to buy their lightened CVD drive axles and outdrives but Answer-RC had the same bits and just went with them. Fioroni definitely makes quality goods and would not hesitate to buy their stuff.
dangerwr is offline
Old 04-25-2011, 09:21 PM
  #5814
DC#14's Avatar
Does anyone run the stock 2.0 body that comes with the 8ight 2.0 nitro buggy? How does it look?
DC#14 is offline
Old 04-25-2011, 09:36 PM
  #5815
Integra's Avatar
The 2 Giant holes for the Nitro Motor and Fuel tank might deter most guys from running it no matter how good it may look.
Integra is offline
Old 04-27-2011, 12:20 PM
  #5816
i did until i got my ebody painted up. i wasnt in a beauty contest so i didnt bother me!
skyler hays is offline
Old 04-28-2011, 09:48 PM
  #5817
Thanks for the reply danger Here's my 8ight
Hop-ups are:
Losi Aluminium Spindles
Losi Aluminium Chassis Braces
Losi Aluminium Servo Horn
Losi Aluminium Servo Saver Top
Fioroni Tractive IV Front Diff
GMK CVD Condoms
Matt
Matt_N is offline
Old 04-28-2011, 09:54 PM
  #5818
RacerX20's Avatar
Nice lookin car there Matt!!
I run the black and florescent yellow theme too.
-Tony
RacerX20 is offline
Old 04-30-2011, 09:26 PM
  #5819
big igg's Avatar
Trader Rating: 18 (100%+)
Can someone help me recommended what battery to run. I have a Losi eight nitro that i converted to electric. So far i have a Tekin RX8 with a Tekin 2050 motor. I bought the Losi conversion kit. Should i get a 3S or 4S? Thanks
big igg is offline
Old 05-01-2011, 12:00 AM
  #5820
Moogumby's Avatar
Trader Rating: 32 (100%+)
what d you guys do with your antennas?
I keep breaking my atenna tubes and thankfully not losing my Rx wire. So what alternatives have you guys been doing?
Moogumby is offline
