Losi 1/8 8ight E 4wd Thread >
Old 04-21-2011, 01:21 PM
  #5791
dangerwr's Avatar
3mm BCE chassis, titanium bits and other goodies to reduce some rotational mass.
dangerwr is offline
Old 04-21-2011, 03:12 PM
  #5792
rcmike's Avatar
Trader Rating: 40 (100%+)
Default losi 1700 bl motor
Can you buy rebuild kits for the losi motors ? cant find it on losi website,thx
rcmike is offline
Old 04-21-2011, 03:33 PM
  #5793
Casper's Avatar
Trader Rating: 34 (100%+)
No there are not parts available for the Losi 8th scale motors. They have all be discontinued as well.
Casper is offline
Old 04-21-2011, 06:00 PM
  #5794
orgnoi1's Avatar
Trader Rating: 39 (100%+)
Hey guys I have a very quick specific question...
I have a buddy who just got the 8ightE... he ordered the wrong motor combo (the 2650kv)... I realize that its WAY over sized in motor... but could he get away with a 12t or 13t pinion on stock spur gearing and keep both the heat down and speeds consistant with the stock gearing on say a 1900kv?
Thanks!
orgnoi1 is offline
Old 04-21-2011, 06:20 PM
  #5795
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Thanks!
I ran a 2100kv with a 13T and it was still fast. I would buy another motor or run three cell.
Bman's 3XNT is offline
Old 04-21-2011, 10:38 PM
  #5796
mblgjr's Avatar
Trader Rating: 86 (100%+)
Originally Posted by DC#14 View Post
what springs are you and john ball running?
Standard Drake E-buggy setup from the TLRacing website.
Email me for the rest.
As far as turning the 1900 down; you can cut the EPA back in the radio; or use a Tekin Hotwire to set it up however you like in the ESC. There's plenty of parameters to make it smoother. Just using the current limiter and backing it down to about 85% will make it less explosive.
mblgjr is offline
Old 04-21-2011, 10:46 PM
  #5797
DC#14's Avatar
Ok good I just got a deal on a 1900. I think I just bought the baddest 1/8 scale buggy ever. You'll have to see it! But there will be no 4x4 sct racing for me... For at least a while.
DC#14 is offline
Old 04-22-2011, 06:57 AM
  #5798
Originally Posted by neobart View Post
Try running the rear camber links in the C hole. That should calm down the rear a little.
For the camber links in the rear do I need to buy longer ones or shorter ones or do the stock ones work in all the holes? I'd like to get another set and get the camber set so i can just swap links without having to adjust at the track.
bacchus is offline
Old 04-22-2011, 07:43 AM
  #5799
Integra's Avatar
No you dont need longer links. I would also advise adjusting as needed.
Integra is offline
Old 04-22-2011, 08:13 AM
  #5800
Why?
bacchus is offline
Old 04-22-2011, 08:21 PM
  #5801
Integra's Avatar
Why?
The overall hassle of removing them to change camber isn't worth it. Buy a Camber gauge and get your self a losi turnbuckle wrench and have at it. Its something you should get into a habit of checking anyways.
Integra is offline
Old 04-22-2011, 10:06 PM
  #5802
dangerwr's Avatar
I think what he is asking is why not change out the tie rods? I never heard of this since they are adjustable. Camber seems to be pretty important and do check it with every tire because it will change slightly.
dangerwr is offline
Old 04-23-2011, 01:55 AM
  #5803
Is there a 48t plastic spur gear available for this car?
iThinman is offline
Old 04-23-2011, 06:54 AM
  #5804
How does everyone check their camber? If I set mine up using plates (-2)then recheck when I install my tires it always seems to be different(0,-1). So which reading is more accurate? Thanks........
Old 04-23-2011, 07:00 AM
  #5805
dangerwr's Avatar
Exactly! I set mine at ride height after I install the tires I am going to run. Recheck ride height after adjusting camber.
dangerwr is offline
