Losi 1/8 8ight E 4wd Thread >
Old 03-07-2011, 07:01 AM
  #5566
dangerwr's Avatar
Originally Posted by justicepool View Post
Hello,
Just purchased my very first 1/8th scale care of any kind. I bought a Losi 8ight-e 2.0 race roller with the Losi Xcelorin ESC/2100kv motor combo kit.
Are there any suggestions for good tuning options or accessories to get? Skid plates? Chassis protector?
It should be here by Friday, can't wait!
Thanks!
John
On the stock 2.0 chassis I like to run the DE Racing skids both front and rear. This will help preserve the chassis a bit as you get familiar with the car. Have fun!!!
dangerwr is offline
Old 03-09-2011, 06:59 AM
  #5567
trgyrcr's Avatar
anyone know the number of teeth on the diff ring and pinion off the top of their head
thanks
trgyrcr is offline
Old 03-09-2011, 09:16 AM
  #5568
Moderator
Muggydude's Avatar
Trader Rating: 92 (100%+)
Spur is 45T Pinion, i think you need to buy your own. 14-16T usually works well.
Muggydude is offline
Old 03-09-2011, 09:49 AM
  #5569
Hello,
Thanks!
John
Good buggy to start with. If the Xcelorin ESC holds up, there is nothing wrong with that combo. Don't let others convince you to change it or that the xcelorin is junk. They had some reliability issues, but the last one I got back from Horizon has done well. They have a horrible abrupt start and it sounds awful, but on the track, you can't feel it and the system runs cool and fast. Chassis protectors front and back are a good idea and shock and diff oils to tune and tires to suit your track. The stock servo horn will never last under real hard driving. Get a Losi all Aluminum one that fits your servo. Really, that is it. The car handles well and is fast without any additional hopups.
chiro972 is offline
Old 03-09-2011, 10:10 AM
  #5570
dangerwr's Avatar
He was asking about the internal diff gear ring (crown gear). I believe it is 45T and the diff pinion which I believe to be 15T. But do not quote me on that!
dangerwr is offline
Old 03-09-2011, 10:14 AM
  #5571
Moderator
Muggydude's Avatar
oops! ddn't read carefully. It's either 45 or 46, and maybe 15 or 16?
Old 03-09-2011, 12:45 PM
  #5572
dangerwr's Avatar
Not sure, but know the Truggy uses 43T/10T but the buggy parts do not have the tooth count listed online. I bet it is in the manual though I do not have it in front of me . . .
dangerwr is offline
Old 03-09-2011, 12:58 PM
  #5573
air8's Avatar
Ring gears are same at 43T. The pinion for buggy is 13t and the pinion for truggy is 10T like danger posted.
air8 is offline
Old 03-09-2011, 01:06 PM
  #5574
dangerwr's Avatar
On an unrelated topic I have been pricing out a number of spares for this upcoming race season. By the time I was done adding I was at $400 but can buy an entire roller on A-Main for $499! I think I will just buy the roller and have an extra chassis, gearboxes and screws!!!
dangerwr is offline
Old 03-09-2011, 01:08 PM
  #5575
Integra's Avatar
blah, i see you were talking the "same" as in the tooth count.
Integra is offline
Old 03-09-2011, 10:46 PM
  #5576
RacerX20's Avatar
Sup guys! I just ordered this kit!
I'm super stoked and cant wait to get it!
Few questions.
What are the most commonly used standard hex sizes this kit uses? I'm looking for a nice standard hex set. All my other RCs used metric. Any recommendations?
Also, I've ordered the Castle MMM 2200kv and I'm gonna run 4s. What pinion size should I run for a good mid ground between torque and speed? 35-45mph would be plenty for the kind of driving I want to do. Mod 1 right?
What wt oils are you guys running in your shocks and diffs? I do plan on racing and want the best handling.
Anything else I should know or order off the bat?
Thanks peeps!
-Tony
RacerX20 is offline
Old 03-09-2011, 11:01 PM
  #5577
dangerwr's Avatar
Few questions.
Thanks peeps!
-Tony
With a 2200kV I would get 13 - 15T pinions and check temps often when you run (test and tune). If you race you probably will set the Punch Control on your ESC at 70 -80%. This motor is a little strong but you will have plenty of fun. You will have endless torque with a large brushless motor so is never an issue. Heat is your enemy. Also make sure your 4S battery is up to delivering the power your motor wants to pull.
Shock setup all depends on your track but d/load the latest Drake setup from TLR website. Uses 42.5W in front with silver springs and 30W in rear with black springs. Diff oil is 5-7-2k from front to back as a good starting point.
dangerwr is offline
Old 03-09-2011, 11:22 PM
  #5578
RacerX20's Avatar
Thanks bro, I appreciate that. Yeah I definitely want to run cool temps. I'll try 14t and work from there. As soon as Hobby King gets their 45c 5AH Turnigys back in stock I'll pick one up. I'm well aware that discharge is everything when it comes to batteries.
How about the hex keys sizes?
-Tony
RacerX20 is offline
Old 03-10-2011, 03:44 AM
  #5579
immarcescibile's Avatar
Hy guys,
I'm writing you from Italy. I have just bought a 8ight EU version already brushless converted.
I'm going to use a Castle-Neu 1512 - 1800Kv motor + Mamba Max Pro esc + external Castle Bec.
Id' like to know if 44T plastic central spur gear will be a good choiche or it woul be better using a 45/46T....
Diff oils: the tracks in which I go are alway bumpy tracks with medium adherence conditions...what kind of oils should I use according to EU/brushless version?? Will 10-10-2 be a good starting point?
Thanks in advance, bye.
Simone.
immarcescibile is offline
Old 03-10-2011, 08:35 AM
  #5580
dangerwr's Avatar
-Tony
Oh yes, sorry! .050", 1/16th, 5/64th and 3/32nd hex drivers. 1/4" nut driver as well. I also think the axles use a 2.0mm grub screw but could just be outta my mind!
dangerwr is offline
