Losi 1/8 8ight E 4wd Thread >
Old 11-14-2010, 03:04 PM
  #5281
Moderator
Muggydude's Avatar
Trader Rating: 92 (100%+)
Cut off that tab in front, one of the big problems on the proline and slipstream. Integra: Jus stick some stuff in the tray at the front, and then put the body on. Keep adding or switching out objects until you find one that barely touches the body. Then measure it! Haha
Muggydude is offline
Old 11-14-2010, 03:43 PM
  #5282
pilotwings119's Avatar
Trader Rating: 50 (100%+)
Originally Posted by neobart View Post
Integra: I don't have the Slipstream body, it's been tossed a long time ago. It did break right across the front hole. Broke the front of the body clean off.
That's how my first Slipstream broke. Then I elongated both body mount holes on the second Slipstream, and it broke at the front the same way. I think allowing the front post to flex is a must.
pilotwings119 is offline
Old 11-14-2010, 05:02 PM
  #5283
Integra's Avatar
I run the little tabs in front on all my body's weather they are supposed to be there or not, When you use the fuel tubing to bring up the front mount for flex it bring the body Up Just enough to clear the tower and the nuts on the back side of the top tower screws with ease.
Thx for the measuring idea.
JC body's aren't supposed to have the flap, But i mark it out and make it happen...for some reason i like them.
Integra is offline
Old 11-15-2010, 03:33 PM
  #5284
chris c's Avatar
Trader Rating: 60 (100%+)
Default 3s gearing
Just curious on gearing for a 8E 2.0 with a 2650 on 3s
thanks
chris c is offline
Old 11-15-2010, 04:41 PM
  #5285
warpig's Avatar
Could you tell me what you like about the handling of the CF towers?
thx... Ben Burtle
warpig is offline
Old 11-15-2010, 09:24 PM
  #5286
pyromania's Avatar
Trader Rating: 18 (100%+)
I guess I'm joining the dark side now.
I'm thinking of converting one of my buggies to electric. I have the losi 1300Kv motor and ESC combo. I plan on running with 4s packs. Gearing as the manual claims (16/45).
How would this combo work for a different variety of tracks?
pyromania is offline
Old 11-15-2010, 09:39 PM
  #5287
Casper's Avatar
Trader Rating: 34 (100%+)
1300 might be a little slow on 4S. I would think you need to geared higher then 16 as that is what we gear our 1700's with.
Casper is offline
Old 11-15-2010, 09:52 PM
  #5288
Integra's Avatar
Honestly Ben, They are lighter then stock and that's about it......Pretty tough to say your going to feel 10-15g overall but I feel the durability is more then enough(pending brand) and i got the whole CF everything going on.
here's a little weight chart for the towers for shi*s and giggles
Integra is offline
Old 11-15-2010, 10:16 PM
  #5289
pyromania's Avatar
Well to tell you the truth, I'll mainly be racing it at HotRod Hobbies.
What gearing would you recommend with a 45t spur?
Old 11-15-2010, 10:22 PM
  #5290
Casper's Avatar
I run the 1700 at HRH as well. I would think you would be in the 17-18 range.
Casper is offline
Old 11-15-2010, 10:34 PM
  #5291
pyromania's Avatar
Thanks Casper.
For right now the 1300Kv is my only choice. I'm not really concerned about top speed since HRH is a very small track.
Old 11-16-2010, 02:49 PM
  #5292
Casper's Avatar
You will be fine with the 1300. Runtime will be awesome as well.
Casper is offline
Old 11-16-2010, 10:56 PM
  #5293
chris c's Avatar
thanks
Thanks Casper for the ideas.
Anyone else have run this same set up what gearing was used
chris c is offline
Old 11-17-2010, 05:40 PM
  #5294
jason07's Avatar
This seems like a dumb question but can someone take a pic of the way their antenna is mounted on their losi eight-e 2.0. I just bought one yesterday and the way I have it mounted, it doesn't look right.
jason07 is offline
Old 11-17-2010, 07:29 PM
  #5295
warpig's Avatar
Nick,
Thanks for the info. above. I used to run CF towers on my MBX5 back in the day to lower CG. I was just curious how the Losi liked it. I don't like my nitro 8ight as of right now. I'm not sure why it drives so terrible.
warpig is offline
