Losi 1/8 8ight E 4wd Thread
#5162
the track has some clay in it but not alot so thats why we dont run the clay compound...
#5164
Ok, so took it to the track today for the first time. Running drakes setup except with 27.5 weight oil up front with green springs (All I had). Ok, so running 2 2s 5200mah 30c hardcase batts in series, along with MMM ESC and Tekin 2050 motor geared 15-45t. Went through two "packs" of 4s, and nothing broke! Really happy witht he handling, steering is amazing, jumps well, and has awesome suspension. My weight bias side to side is pretty much perfect in the rear, and slighlty heavier battery side in front. Didn't seem to affect it much. Only two problems the whole time: First, a rear shhock screw backed out. Second, the switch kept turning up on hard landings, so i moved it and had no problems. Temps were (after full run): Batts: 105 ESC: 120 Motor: 180 (is this too hot, should i gear up, down? Or keep it as is?)
So here's the best part: 22 minutes hard 100% track runtime with LVC set at 3.1V! Really happy with that, much more than i expected. Will be able to run the nitro 20 minute mains without 1 battery change!
#5166
Any idea if those Left-handed screws will hold after the arms have been threaded with Right-handed screws?
#5168
so i'm looking to get a new esc for my buggy. i'm prob going to get a mamba monster. my question is how are othe esc mounted. meaning what r u guys using to mount them to the chassis? i was thinking double sided tape,but was thinking it may not hold. so any insight would be very helpful also include any pics. thank you
#5169
#5171
The motor is a a little different story. Try to keep it under 180F or less . . .
#5173
how do you guys put on the traxxas mmm ESC protector. I bought one after reading a few posts here but when I received it, I noticed that there is no screw holes on the losi converion kit to intall the traxxas part. can anyone please post some pics of it. thank you.
#5174
were can i find a set up that i can download for indoor hard pack super grip,and very smooth... we usually run blue barcodes on 10th,very tight and technical track?
i get my Losi today and i wanna put a set up on it... and i will be going thru the whole car this weekend to refresh everything...... seems like most of our other 1/8 e guys for indoor are using the super soft wishbones and love them.... i believe the car will have the box stock set up on it i was told but anyways a set up would really help thanks guys!!!!!
This is a great starting setup that was developed on a similar track to what you described.
http://www.losi.com/ProdInfo/Files/L...6_DrakeStd.pdf
I run this with only a few minor tweaks. I like 55 pistons with 37.5wt oil for a little more pack in the front and I run the inclined spindles.
I definitely need some of these.
#5175
Well, my 8ight has never been faster... then I forgot how to drive! I managed to win the race for my opponent... (This was an unusual race because the BL 8th scale turnout was low. So we ran the truggies and buggies together.)
+ YouTube Video | |
