Losi 1/8 8ight E 4wd Thread >
Old 08-31-2010, 09:51 AM
  #4951
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Integra View Post
buggys dont have a tranny.
enter 1
Not totally true. You need to take into account the pinion to ring gear at the front and rear diffs. I don't know what ratio that is though!
Casper is offline
Old 08-31-2010, 10:37 AM
  #4952
Integra's Avatar
Transmission Gear Ratio
This is the final ratio of the whole transmission from input shaft to output shaft, which includes all the internal gears. The result should be a number larger than 1.
If your vehicle does not use a transmission, enter 1 here. If your vehicle uses a center differential, this ratio will be part of the spur/pinion ratio and you should enter 1 here.
Open the dropdown list to select some popular preset values. This will automatically fill in the correct value for that transmission.
Integra is offline
Old 08-31-2010, 02:50 PM
  #4953
monkee's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ScottKelly911 View Post
I'm currently running a 43T Spur and a 15T Pinion on a 2650 with 4s and it's pretty much overkill on most tracks, so if you went with a 15 or 16T pinion you should be fine. It really depends on what you're looking to do though. if you're looking to extend run time to make a 20 min main, I'd suggest going down to about an 11 or 12T pinion as well as increasing the spur size to get the most run time possible. If you're practicing on a track or have 5-10 min mains (you should get about 15+ min of run time if you're driving hard), then try out around a 15 or 16T pinion. If you're just bashing and enjoy doing some high speed runs, then try out an 18 or 19T. With the 2200 you wont have to worry about heat issues, so go out and enjoy! I hope that helps.
thanks!
i got the mamba today.. it came with an 18pinion.
ill put it in for now but i think ill order a 13 or 14 to try on the track
monkee is offline
Old 08-31-2010, 07:40 PM
  #4954
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
I hear the guys in here are diggin the TL 8E buggy....So here is a body I just did for one.
...Jim
W.E.D.
www.wedjim.com
W.E.D.Jim is offline
Old 08-31-2010, 09:53 PM
  #4955
Integra's Avatar
...Jim
W.E.D.
www.wedjim.com
are those peter's ?
Integra is offline
Old 09-01-2010, 12:29 AM
  #4956
monkee's Avatar
what brand pinions would be recommended?
i just put on the 18pinion that came w/ the 2200 castle and its teeth seem larger than the teeth on the spur.
i have not yet run the buggy as i dont have a servo yet
these are bad pictures.. not sure if you can actually see it
actually in the second pic, i see plastic shavings from the spur on the chassis.
doesnt seem right
monkee is offline
Old 09-01-2010, 02:02 AM
  #4957
dangerwr's Avatar
I have tried a few brands, including Castle, and really like the Hot Bodies. They are cut VERY well and are really quiet on the Losi spur. I want to try the Robinson Racing Mod 1 some day but Hoopty Buckets, I am sorry, Hot Bodies have been the ticket for me and a few others around here . . .
From the looks of the picture you have a Mod 0.8 pinion--you will want a Mod 1 size!
dangerwr is offline
  #4958
ScottKelly911's Avatar
doesnt seem right
The reason the pinion and spur dont mesh correctly is because the pinion that the motor came with is size mod .8 which is basically 32 pitch. The Losi 8ight uses mod 1 pitch. The best thing to do is to get yourself some Robinson Racing hardened steel (not aluminum) pinions. You'll notice they say 5mm bore, that's the size used on 1/8th scale systems like the Mamba Monster motor shaft.
http://www.amainhobbies.com/index.ph...filter_mfr=198
ScottKelly911 is offline
Old 09-01-2010, 08:14 AM
  #4959
Casper's Avatar
I have run the robinson and the losi and both work great. The losi's have a reputation for not staying on the shaft but that was due to an old design with a small set screw. The new ones with the larger set screw work great and you can never go wrong with having the spur and pinion come from the same company. Just make sure you get a large set screw if you can.
Casper is offline
Old 09-01-2010, 09:32 AM
  #4960
Integra's Avatar
RR over here.
Integra is offline
Old 09-01-2010, 08:15 PM
  #4961
W.E.D.Jim's Avatar
Integra, yeah they are, but you knew that by now since i'm late getting back in here.
...Jim
W.E.D.
www.wedjim.com
Old 09-02-2010, 07:37 AM
  #4962
Integra's Avatar
...Jim
W.E.D.
www.wedjim.com
for sure buddy, Ill be thinking up somethign new to try on the next run of body's...Nitro buggy's a little beat, But that always seems to be the one that goes first. (That's it, Next time we'll do X2 on the nitro bug)
Thx again for everything Jim.
Integra is offline
Old 09-03-2010, 12:31 AM
  #4963
monkee's Avatar
just got my jr steering servo...
want to make sure i get the right parts..
tell me if i have the right stuff please!
http://www.amainhobbies.com/product_...m-Servo-Arm-JR
http://www.amainhobbies.com/product_...ering-Link-Set
and these are what screw each side of the steering link to the servo arm and the servo saver?
http://www.amainhobbies.com/product_...Head-Screws-10
exploded view of 8ight
http://www.losi.com/ProdInfo/Files/L...sExplosion.pdf
monkee is offline
Old 09-05-2010, 09:17 PM
  #4964
racer x 1's Avatar
Trader Rating: 27 (100%+)
hey guys, new to the losi got myself a 2.0 e and i was wondering if you guys could kindly post some pics of ur electronic layout and also what would be the best way to mount my rx8 to the car? thanks
racer x 1 is offline
Old 09-05-2010, 09:23 PM
  #4965
Djballen's Avatar
Here is a great starting point.
Attached Thumbnails Losi 1/8 8ight E 4wd Thread-losi-layout.jpg   Losi 1/8 8ight E 4wd Thread-losi-layout-2.jpg
Djballen is offline
