Losi 1/8 8ight E 4wd Thread
#4876
Yes ditch the rear motor support. This has been the leading cause of stripped gears so far. The motor support pushes up on the motor under hard landings and messes up the gear mesh. Take off the rear support and you should have much better luck with your spur gears. I have been running the same one for almost a year now.
#4877
X2
#4878
Thanks for the replies guys. I'll definitely give that a try. I really didn't want to go to a metal spur gear.
#4879
i to herd to ditch the rear motor support i ran it for months never had an issue than i ditched it because it made setting the mesh easyier..........still no issues almost a year now and i hardly ever strip a spur and i run plastic.
make sure you brakes are not turned all the way up as going from full speed max rpm to instant stop if you brakes are turned all the way up can take a toll on drivetrain parts including the spur
#4880
John. The rear mount seems to only be an issue on hard landings off big jumps where you get lots of chassis flex. I have known guys that ran it for a while with no issues but then get the tracks where they start to strip spurs as the landings are harder. It is not a bad thing to remove it.
#4881
Some TL8E bodies, stock and a PL Slipstream just painted up...One is not as it seems though if you look closely?
...Jim
W.E.D.
www.wedjim.com
...Jim
W.E.D.
www.wedjim.com
#4882
Oh me oh my jim......your such a tease.....Now i want new too.
Hey btw how did my buddy peter's body's turn out ? any pics ?
Dirty mugen Lol
Dirty mugen Lol
#4883
...Jim
W.E.D.
www.wedjim.com
...Jim
W.E.D.
www.wedjim.com
#4884
R/C Tech Elite Member
I just converted my 2.0 to an e car..........I put in the Losi conversion, I am getting a rx8 system and a 2050(going to get a 1700kv as well for indoor) and a Tekin 4s lipo........is there anything I need to know or be aware of about this conversion as far as mods/tips etc.? what is the rear motor support, the plastic part that the can sits in, take it out? thanks! TW
also, what is a good starting setup for a high-bite/tight/hardpacked/smooth indoor layout?
#4885
Yes take out the rear motor support. It does more harm then good.
Start with this setup and tune from there.
http://www.losi.com/ProdInfo/Files/L...6_DrakeStd.pdf
#4886
how hard was the install?
thinking about converting my nitro as well for my son to drive
thanks
c
#4887
Thanks very much guys!
Integra, not yet, but soon, I believe they will be in this weeks work. I'll know for sure in a night or two how many i'll be able to get in this week coming up.
...Jim
W.E.D.
www.wedjim.com
...Jim
W.E.D.
www.wedjim.com
#4888
I'm gonna ditch that rear support and hopefully the problem will go away.
#4889
TL8E BODIES.
...Jim
W.E.D.
www.wedjim.com
...Jim
W.E.D.
www.wedjim.com
Regards.
#4890
I never had this problem with my other motors and I have been racing RC for almost 3 decades, so I know how to set mesh.
This motor is not that high of a KV. I think 2250kv, but it is just insanely fast. I'm wondering if the plastic spur simply won't hold up to it or if the chassis is flexing too much with the stock plastic chassis braces.
When it happens I never see any evidence that the motor mount has loosened or moved.
Should I try stiffer braces? (I'm not optimisitic about that because the brace ends so far from the spur gear)
Or just bite the bullet and go with a metal spur gear?
