Losi 1/8 8ight E 4wd Thread >
Old 10-28-2008, 10:42 AM
  #436
Trader Rating: 14 (100%+)
I posted a few pages back where my losi system was giving me inconsistant performance and some high temps. Well Losi is definintely being pro active and trying to make sure this is done right. A few day's after my post, the product manager for the Xcelerin line PMed me and asked me a few questions and narrowed down my problems to a defective rotor. As soon as he got his hands on one he sent it out to me. BRAVO!
spcpicard is offline
Old 10-28-2008, 11:33 AM
  #437
I sent my broken Losi 1/8 ESC to horizonhobby 5 weeks ago ... and I am still waiting for a new one . Good customer service
Luckily I can use my MGM 16224 in the meantime ... if I receive the losi ESC back I will put it on ebay immediately.
TopAs is offline
Old 10-28-2008, 11:34 AM
  #438
sounds like a great buggy. i think i will sell my ofna e-jammin and get one.
bring it on is offline
Old 10-28-2008, 06:31 PM
  #439
joecool's Avatar
Trader Rating: 22 (100%+)
Default selling mine
anyone looking for a good deal on a 8ight e? i just posted mine on ebay check it out
http://cgi.ebay.com/ws/eBayISAPI.dll...=tab%3DSelling
joecool is offline
Old 10-28-2008, 07:03 PM
  #440
hlpressley's Avatar
Trader Rating: 209 (99%+)
Have any of you guys that have driven this buggy had any problems with too much brake? I was able to run mine this afternoon and it has way too much brake. I set the drag brake to the lowest selection via the programming card and it still has too much. It is so much that if you are on flat ground and let off the throttle it will literally slide on the dirt as if you jammed the brake. Any suggestions?
hlpressley is offline
Old 10-28-2008, 11:58 PM
  #441
Drift_Buggy's Avatar
Has anyone played around with diff fluids in their 8ight-e yet?
Drift_Buggy is offline
Old 10-29-2008, 05:55 AM
  #442
lxmuff's Avatar
It is extremely strong compared to the MMM. You have to turn down the brake in your transmitter to get to lower level if you used the lowest in the card.
lxmuff is offline
Old 10-29-2008, 06:27 AM
  #443
Miller_Time's Avatar
Trader Rating: 11 (92%+)
It sounds like the problem he has is actually the drag brake though. It goes to strong brake when he releases the throttle, but isn't applying brakes on the transmitter. Are the drag brakes that strong or did you mean the applied brakes?
Miller_Time is offline
Old 10-29-2008, 06:40 AM
  #444
lxmuff's Avatar
I didn't use drag brakes on mine, so it may be the same thing with just brakes.
For brakes, I use 30 on the esc and 15 on the radio epa to be similar to the 60 on the MMM and 50 on the epa for the similar response. Good Luck.
lxmuff is offline
Old 10-29-2008, 07:03 AM
  #445
hlpressley's Avatar
I have the drag brake and the applied brake at the lowest setting via the programming card. I have my radio (3PK) brake EPA all the way at 0. I am not sure how it could be the radio being that I never have to apply any brake before it goes into a slide on the dirt. If it were the radio why would it apply that much brake when the radio is in the nuetral position? Thanks
Old 10-29-2008, 07:53 AM
  #446
R40Victim's Avatar
Check your trim, it may be a bit on the brake side. Set it to where the car is almost ready to move, that should do it.
R40Victim is offline
Old 10-29-2008, 09:11 AM
  #447
TLRacing
Todd Hodge's Avatar
Try reducing your braking percentage down to 10%. Drag brake does not affect push brake.
Todd Hodge is offline
Old 10-29-2008, 09:27 AM
  #448
DRRC's Avatar
Trader Rating: 59 (98%+)
Todd
Hope you can help me out
I still have not found the right balancer tab for the 4s 5000 losi pack
using the hyperion charger
I have bought 4 tabs JST, TP, Losi EFT and a hyperion one and still would not fit the balancer tab on the losi
thanks
DRRC is offline
Old 10-29-2008, 09:59 AM
  #449
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by DRRC View Post
Todd
thanks
The balance connector is the same as on Thunder Power batteries
rocketron is offline
Old 10-29-2008, 10:12 AM
  #450
DRRC's Avatar
I studied the TP connector and the battery tab does fit but not perfect
There are 6 pins and had to use the first 5 on the left and it balanced the battery well
I had .2v difference in a few cells but not a lot
thanks guys
DRRC is offline
