Losi 1/8 8ight E 4wd Thread
#4171
I bought a set of black rears and green fronts because of the extra weight of 'E' converesion and I wore a set of fronts out last year(had the spring collar ran all the way down and could not achieve proper ride hieght). I swapped the front but not the rears. I like it with the green fronts but am going to try the black rears just yet.
#4172
lowcel--Adam runs that servo saver arm on his cars. They just got back in stock so I have one on order and will be putting it on my car when I get it.
Hate2Looz-- I run the black rear springs and the stiffer rear swaybar on my 8-E. I have not really run outdoor with the car yet. The only outdoor experience I had was on a blue groove smooth track. I like the stiffer rear springs that take out roll (with the swaybar) to support the rear end. I run on tracks with pretty good traction though. Go back down in springs if that is how you feel comfortable. Make the car work for you. If the cars were one size fits all there would not be tuning options!
#4173
#4174
I feel the nitro rear is too soft for my liking. I have never run the nitro 8 so not sure how it feels on that car but I felt the kit setup (basically the nitro setup) was too rolly. (is that a word
). I stiffened up both ends and like how the car feels more consistant to me.
#4178
I SUCKED THIS WEEKEND RACING, I DONY KNOW WHAT IT WAS? MY FRIEND RACED HIS TEKON CHASSIS ON HIS CAR AND HE WAS 3 SEC FASTER ALL OVER THE TRACK. THEN IN THE MAIN I STRIPPED A 45 TOOTH SPUR! MAN I NEED TO START OVER ON A SETUP. WHAT SPUR DO U USE ON THE CAR. WHAT SETUP WOULD U SAY TO USE ON AN OUTDOOR TRACK???
#4179
Casper, I know what ya mean by (rolly). I ran my losi for the first time this week and it seemed to have a lot of chassis roll, side to side. It would roll over and if there was a bump or rut it seemed to really unsettle it. I haven't tried the heavier rear sway-bar yet. I'm afraid the heavier sway-bar will make it too loose. Should I go with heavier front oil or a heavier front sway bar if its too loose? I did try your oil and piston set-up in the front and I liked the way it jumped and turned.
#4182
I run the 43 on my car right now but that is because I run the 2100 on 3S and am running some pretty call cars. (20/43) I would stick with the 45 unless you are putting big pinions on your car.
For outdoor I would start with the kit setup and then tune from there. The kits setup is basically a nitro setup which should be good for outdoor. Without actually driving on a real 8th scale track yet with this car I don't have a baseline yet for real outdoor.
T&D-- A lighter front sway bar will add steering and make the rear end more loose. I like the extra front pack going to 55 pistons gave me. The stiffer rear springs, oil and sway bar made the rear end more consistant for me and allowed the rear end to rotate for the tighter tracks I run at. These "E" cars have a bit more weight in them with 4S setups then the nitro guys so we are going up in oils and springs to compensate. Does not hurt to give it a try. Swaybars are pretty easy to swap out if you don't like it and they give them to you in the kit so it is a no cost change. Don't be afraid to try stuff. That is the only way to learn.
#4183
Are you still running the motor support under the motor? If so take that out. I think this is the leading cause of stripped spurs. As you have hard landings the chassis pushes up on the motor and messes up the spur gear.
#4185
