Losi 1/8 8ight E 4wd Thread >
Old 03-03-2010, 09:13 PM
  #3751
Trader Rating: 29 (97%+)
It depends on the packs your running & what you need to do. Its likely going to take an hour to charge a pack.
party_wagon is offline
  #3752
Casper's Avatar
Trader Rating: 34 (100%+)
I would want at least 2. The motor and battery you get will determine your runtime. Getting 2-3 hours of runtime will take a quite a few battery pack runs.
Casper is offline
Old 03-04-2010, 12:26 AM
  #3753
SpEEdyBL's Avatar
All you need is 2 zippy packs, a good charger, and you will be running non stop. The 40c zippy packs can be charged at up to 5c or in about 12 minutes if your charger & powersupply can handle it. You can put the packs on the charger right after running since they should barely get warm. I use the hyperion EOS0610i and alway use the 10 amp setting which allows me to charge a 4000 mah pack in about 25 minutes, but the last time I have ever needed to wait for a pack to finish charging was about 8 months ago.
Also, choosing the right motor is must in order to be able to run non-stop. For 4s, shoot for 2000kv or less and you should be good. If your esc can handle 6s, then a good setup would be a 3300 mah 6s pack and a 1400kv motor. That will get you longer runtimes and potentially faster charge times than a standard 4s 5000 mah setup.
SpEEdyBL is offline
Old 03-04-2010, 12:50 AM
  #3754
are you sure that the zippys can handle that charge rates?
I own several 2s 5000mah 25c packs. i think they are supposed to be charged at only 1c?
cruysen is offline
Old 03-04-2010, 06:04 AM
  #3755
thanks. i'll be sticking with 2x2 4's though, thats what i run in my erevo, and i want to keep all the batteries the same for a few reasons.
i'll look for a 2000kv or less setup
theagentorange is offline
Old 03-04-2010, 07:15 AM
  #3756
Integra's Avatar
Imo charging above 1-2C is not needed....your just asking for trouble
Integra is offline
Old 03-04-2010, 10:41 AM
  #3757
the roller i'm looking at actually comes with the stock motor, but the esc is toast. what would be the best ones for me to look at getting to replace it?
Old 03-04-2010, 02:46 PM
  #3758
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Castle Creations Mamba Monster and Tekin RX8 are two of the best out there. I would lean towards the Mamba because the motor you have is sensorless(don't need the sensor capabilities of the tekin). Both would be great choices though. I have heard nothing but troubles with the Losi ESC so I would advise you steer clear of that one.
JAMMINKRAZY is offline
Old 03-04-2010, 03:36 PM
  #3759
Casper's Avatar
I have seen problems with all the ESC's out there. I have had good luck with the losi one. The lastest software update decreased motor temps by 30 deg on an ESC I upgraded the other day. Just keep the brakes turned down on the losi ESC. (20% is the recommended starting point and still a TON of brakes). I think having the brakes too high is killing the speedo's off but they are figuring that out which is why the lower settings in the latest firmware update. I have seen CC, Tekin and LRP all smoke at our track. I will admit the CC is one of the more reliable systems out there.
Casper is offline
Old 03-04-2010, 03:42 PM
  #3760
Very true! None of them are perfect, and given the right circumstances any of them will smoke. I have seen good and bad things with the losi ESC. A buddy of mine smoked one a bit ago, but I'm not sure what firmware he had on it. My CC system has been holding up and preforming excellently!
Old 03-04-2010, 06:51 PM
  #3761
jthomas143's Avatar
Trader Rating: 48 (100%+)
DELETED!
jthomas143 is offline
Old 03-04-2010, 08:02 PM
  #3762
Trader Rating: 14 (100%+)
hi,
can I run 2 cell hardcase lipos w/ either mamba monster or tekin? how fast would that be and is it possible for me to get a higher KV motor running w/ only 2 cell lipos?
thank you
NSLST is offline
Old 03-04-2010, 09:53 PM
  #3763
TeckLancer's Avatar
Trader Rating: 16 (100%+)
ive had my losi esc for about a year now. and i have last sumers firmware. and i have had nuthing but luck with it. i race alot and i drive it hard, and has never givin me any problems. im running a losi 1700 with a 4s ip 5400 pack
TeckLancer is offline
Old 03-04-2010, 11:05 PM
  #3764
Casper's Avatar
Originally Posted by NSLST View Post
hi,
thank you
2S even with a high KV motor will be very hard on the battery and still not very fast.
Casper is offline
Old 03-04-2010, 11:08 PM
  #3765
Guest
Casper, what brand of lipo do use???? OR ANY OF YOU GUYS THAT RUN LOSI 1/8 BUGGY, WHAT BRAND OF LIPO DO U ALL RUN? I AM UNDECIDED ON WHAT LIPO TO USE I WANT 3 GOOD LIPOS TO BUY. I am using Mamba monster with a 2650 and a 1800. I got a protek icharger 610.
LOSIRACER77 is offline
