Losi 1/8 8ight E 4wd Thread >
Old 02-27-2010, 08:01 PM
  #3706
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by dkehres View Post
Do the latest Mamba Monster motors still use a 3mm screw vs the 4mm screw used on the losi motor mount? Does the 3mm screw work OK on the losi mount? Just ordered the MM and want to make sure I have the correct hardware to mount it. Thanks for any feedback.
I got mine earlier this year and it only had 3mm holes. I just drilled and tapped them for 4mm screws. Much more solid than 3mm screws and they fit the losi mount how they are supposed to. You can buy a nice 4mm drill/tap set from dubro for under $10 if you don't already have one. It's pretty easy to tap out the aluminum. Just make sure you remove the end bell from the motor to tap it so you don't damage the motor internals.
JAMMINKRAZY is offline
  #3707
brofroe's Avatar
Trader Rating: 20 (100%+)
A friend of mine used 3mm screws to hold a Nue motor on his 4mm Losi mount with no problems. He is a way smooth driver too, no lawn darting over jumps etc., so this may have helped. make sure you double check the length of your screws so you don't damage the motor.
brofroe is offline
Old 02-27-2010, 08:02 PM
  #3708
brofroe's Avatar
Or this is a better idea.
brofroe is offline
Old 02-27-2010, 10:30 PM
  #3709
Guest
Default gearing
I need alittle help with gearing a 2650 Mamba monster setup on the eight e buggy? Where do I start? I got a 14-15-18- pinnon and a steel 48 an plastic 45 spur. What else do I need guys?
LOSIRACER77 is offline
Old 02-27-2010, 11:00 PM
  #3710
Casper's Avatar
Trader Rating: 34 (100%+)
3S or 4s?
Casper is offline
Old 02-27-2010, 11:25 PM
  #3711
Guest
Originally Posted by Casper View Post
3S or 4s?
Sorry. I am using 4s, got to be roar.
  #3712
R/C Tech Elite Member
tom2tone's Avatar
Trader Rating: 99 (100%+)
Use this chart to figure out your gearing...
http://www.scriptasylum.com/rc_speed/_top_speed.html
I'd gear for around 40mph and work around there.
tom2tone is offline
Old 02-27-2010, 11:29 PM
  #3713
Guest
How much run time do u get?????I want to run 20minutes
Old 02-27-2010, 11:37 PM
  #3714
tom2tone's Avatar
I actually haven't checked my runtime with only 5 minute quals and 10 minute mains. 20 minute run times will be tough, what motor are you running?
tom2tone is offline
Old 02-27-2010, 11:40 PM
  #3715
Guest
I will be starting with a Mamba 2650 to go to a 1800.
Old 02-27-2010, 11:43 PM
  #3716
tom2tone's Avatar
yeah you won't get 20 minutes with the 2650 and 4s. But as far as I've heard you should be able to get close with the 1800 and 5s or 6s. It's supposed to run cooler and speed should be about the same compared to what you are starting out at.
tom2tone is offline
Old 02-27-2010, 11:48 PM
  #3717
Guest
I am going to get1 5400 proteck 4s and 1 6500 Max amps 4s. I was hoping to get really close or better than 20mins. I just want to run electric with gas a bet them in a fair race.
Old 02-28-2010, 12:07 AM
  #3718
Casper's Avatar
It will be hard to get to 20 min with the 2650. Might want to look into the 8000mah 3S.
You can run 3S with the 2010 ROAR rules.
See page 66 of the ROAR rule book.
http://www.roarracing.com/downloads/..._Rule_Book.pdf
The other way is go low KV to make the system more effecient. I think you will need more then 5000mah to get 20 min still.
Casper is offline
Old 02-28-2010, 12:16 AM
  #3719
Problem is that will never be a fair race. Electrics have a large performance advantage over nitro buggies.
Old 02-28-2010, 11:21 AM
  #3720
could someone tell me exactly what pitch/size screws i need
los2 is offline
