Losi 1/8 8ight E 4wd Thread >
Old 01-08-2010, 11:12 AM
  #3526
jetbill007's Avatar
Trader Rating: 20 (100%+)
Thumbs up 8ight-E 2.0 Roller For Sale
2.0 E Roller + extras for sale. Custom Body
http://www.rctech.net/forum/r-c-item...-w-extras.html
jetbill007 is offline
Old 01-08-2010, 01:53 PM
  #3527
yfzracer912's Avatar
Thumbs up
Originally Posted by novaa View Post
hi to all losi eight 2.o owners,
may i know that is the tekin t8 motors can be fitted to the team losi 8e motor mount without any issues ? is it a perfect fit for it ??
Yes it is!!
yfzracer912 is offline
Old 01-08-2010, 09:22 PM
  #3528
Default thanks
Originally Posted by yfzracer912 View Post
Yes it is!!
thank you very much..
novaa is offline
Old 01-08-2010, 10:02 PM
  #3529
Suspended
Trader Rating: 18 (100%+)
I have an 8ight-e and 8ight-e/T both are 1.0's, what would be the best parts to start with(or most needed) to make it closer to a 2.0?
Thanks..
bag of doritos is offline
Old 01-09-2010, 12:16 AM
  #3530
Thanks..
For the 8ight T don't bother trying to upgrade. It would cost a lot more than just buying a new 8T 2.0.
For the 8ight B the biggest performance change is the 2mm longer flex tune chassis. To run this you will also need the 2.0 center rear drive shaft. Other than that running a current 2.0 suspension set up will get you very close to a 2.0 in performance. If you want to change more stuff the shock towers would be next.
The other changes made to the 2.0 that would carry over to an electric conversion were 4mm (thinner) turnbuckles and the steering rack and servo saver. Some have had problems with the 4mm turnbuckles not holding tune and a lot of guys have switched back to the 1.0 steering system.
GO-RIDE.com is offline
Old 01-09-2010, 04:59 PM
  #3531
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default 2.o T e
I got my 2.0 T e 2day "used"n i was looking over the drive train bearings n so on i noticed the center diff was not smooth ok,the top brace is fitted 1 side alum one not as soon as i remover the top it freed it up I had to make the screw holes bigger and grind off the fitted part to free it up night n day diff ,do they make alum diff carriers? how should i gear it running 5s tekin 1550kv tight indoor.. think it has a 45 on it.. i can post pic's if needed.
Customworksking is offline
Old 01-09-2010, 07:50 PM
  #3532
mrramirez's Avatar
Trader Rating: 81 (100%+)
Can anybody please post a link or two of where I can buy a steel center diff spur gear. One that will fit my 8e 2.0 buggy without any modifications. Thanks
mrramirez is offline
Old 01-09-2010, 08:17 PM
  #3533
http://www.rc-monster.com/search.php
Old 01-09-2010, 09:53 PM
  #3534
Integra's Avatar
Problem with the plastic spurs ?
Integra is offline
Old 01-09-2010, 10:18 PM
  #3535
mrramirez's Avatar
Yeh, no matter how hard I try to make sure that the gear mesh is set properly it always wares out quickly.
Old 01-09-2010, 11:09 PM
  #3536
Jube's Avatar
Trader Rating: 43 (100%+)
Are you using the brace under the motor?
Jube is offline
Old 01-09-2010, 11:24 PM
  #3537
mrramirez's Avatar
No motor brace, I don't use it on either of my buggys. The problem started when I replaced my motor and esc with the mamba monster/2650kv motor. On my hyper 9e I run the stock steel spur gear without any issues at all (same setup).
Old 01-10-2010, 08:29 AM
  #3538
Integra's Avatar
Ive been running my plastic spurs since day 1..as a matter of fact im still on the first one.
Something's a miss here if your blowing through spurs.
Integra is offline
Old 01-10-2010, 09:11 AM
  #3539
Jube's Avatar
Im with Nick on this. Ive been thru a couple but for other known reasons. You have something up fer sure.
Jube is offline
Old 01-10-2010, 09:16 AM
  #3540
Just to be on the safe side is there any plastic cover to put on the spur-pinion to prevent debris to get in between ?
Emmeth is offline
