Losi 1/8 8ight E 4wd Thread
#3347
You don't want the rear suport to actually touch the motor, the chassis flex would apply excess pressure to the rear of the motor. The fans are hit and miss. My first one stopped immediately, the second one I have is working great. My First speedo fan I replaced with a Novak 30mm clear fan and it was great. The pinions just need to be tightened with a GOOD wrench the correct size. I havent had one come off ever.
For the FEMALE end of the connector to match the stock one on the speedo, see horizon hobbies and search EC5
#3348
As far as the Batt. connectors go the are e-flite ec5 connectors. My local Hobbytown has them. Look with the airplane stuff, they may have them hidden there.
I have only had one pinion failure, and that was do to me not tightening it down enough. My 15 tooth losi has a 5/64 setscrew, not sure why the would deviate from that.
#3349
Is the 1.0-e and 2.0-e body's the same the reason I ask is because all I can find is one body and wanted to make sure they were the same before I ordered it, thanks
#3358
Try a 4S 5000mah lipo atleast a 25C or 30C.
For the pinion, start with 15t.
#3359
Try 13 or 14T. 15T will make it run pretty warm. I'm running the same motor.
