Losi 1/8 8ight E 4wd Thread >
Old 08-04-2009, 05:44 PM
  #3271
Trader Rating: 18 (100%+)
Originally Posted by racer357 View Post
rene, I lost my losi fan very quickly as well. I replaced it with a clear Novak fan and it has performed great for over a month.
is that part number 5645? Does it bolt right up? Thanks
infanterene is offline
Old 08-04-2009, 07:21 PM
  #3272
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
So far 3 months with the original Tekin RX8 fan and no problems yet.... come to think of it how do you test to see of it's working. What's the process?
XXXDad is offline
Old 08-04-2009, 07:38 PM
  #3273
Jube's Avatar
Trader Rating: 43 (100%+)
should come on for a sec when you power up.
Jube is offline
Old 08-04-2009, 07:59 PM
  #3274
rene, it is # 5652 , direct fit, bolts on with shorter screws is the only difference.
racer357 is offline
Old 08-04-2009, 08:01 PM
  #3275
Jube's Avatar
get off the laptop and drive
Jube is offline
  #3276
Integra's Avatar
push and hold mode...it should click on....mine did at least.
Integra is offline
Old 08-05-2009, 12:42 AM
  #3277
RJNicholson's Avatar
Default Gearing Question
I just picked up an Electric 2.0 and I'm wondering if there is any other spurs to run other then plastic? If so where can I find them, and are they the same smaller sizes I'm seeing in Electric? I don't care much about the noise it makes.. I think it sounds awesome like a damn chain driven car.
Also, should I stick with the stock 45/15?
Is anyone running the Center SD? If so are you changing the spur to a smaller size, or changing the Pinion?
Any insight to these questions would be great. Thanks everyone.
Sorry I'm lazy and don't feel like reading through this Thread as well to see if this was talked about, or use the search feature.
This Roller has the Stock motor and ESC equipped.
-Richard
RJNicholson is offline
Old 08-05-2009, 01:15 AM
  #3278
az00lude's Avatar
-Richard
Losi conversion kit comes with 45T metal spur. I'm sure that will firt just fine.
I'd drop to 14T pinion for longer runtime and easier on the electronics. 14T should be plenty of speed for any track. 13T for small tracks.
az00lude is offline
Old 08-05-2009, 05:56 AM
  #3279
air8's Avatar
Anyone tried a Peltier? Last year the 1/8 conversion Thread people were posting up about the use of a peltier junction module. The only downside I think, was the amount of ice/condesation that formed.
air8 is offline
Old 08-05-2009, 07:16 AM
  #3280
yfzracer912's Avatar
For those like myself who have never heard of peltier before here is a quick link. http://www.heatsink-guide.com/peltier.htm
yfzracer912 is offline
Old 08-05-2009, 08:12 AM
  #3281
Integra's Avatar
I was just gonna say....what the Tooooot is a peltier
Integra is offline
Old 08-05-2009, 08:27 AM
  #3282
rookie question, but does a smaller pinion with the same 45T Spur gear mean more torque and less top end?
SwanSong is offline
Old 08-05-2009, 08:55 AM
  #3283
Trader Rating: 22 (100%+)
Silly question..anyone poke holes in their body to get air flowing in for cooling? If so what's an ideal position for the 8ight? I plan on running the MMM 2200KV and a zippy 5000ma 20c and all these threads got me scared sh!tless about it "thermaling"..haha
nitronutzzz is offline
Old 08-05-2009, 09:15 AM
  #3284
dangerwr's Avatar
Well, to answer your question--I would cut out the front window and use a glue gun to place in some screen. I do this and it appears to work well--looks cool too and get a lot of compliments (if you are into that kind of thing).
Now, your system will not "thermal" since it is sensorless--it will simply overheat. Thermaling, in my opinion, is when a sensored brushless system shuts itself down b/c it gets too hot. The MMM combo will simply get too hot and create damage if operated incorrectly.
I believe your concern should be the 20C packs. Make sure you know the amps that these packs deliver and what the motor wants. If your motor wants to draw a higher continuous current higher than your packs deliver you run the very likely risk of "puffing" the packs. This, if you do not already know, essentially destroys the batteries and become a potential fire hazard if you try to recharge them.
Many will recommend you do not run 20C packs with 1/8th scale but really depends on your motor. Just so you know . . .
dangerwr is offline
Old 08-05-2009, 09:24 AM
  #3285
Your right, the bigger the pinion the higher the top end. And as for the spur gear the bigger you go the more TORQUE you get(loose top end).
Going down a tooth on the pinion is simillar to going up on the spur and vise versa.
