Losi 1/8 8ight E 4wd Thread >
Old 08-01-2009, 10:25 PM
  #3241
Trader Rating: 18 (100%+)
I am happy to report that I was able to run the 20 minute main no problem. All stock losi setup, even Losi lipo. I like the car but it feels a little unstable and the rear likes to kick up.
infanterene is offline
Old 08-02-2009, 06:22 AM
  #3242
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I was having the same problem. Try the stock 25wt with silver springs in the rear or 32.5-35 with greens. If you have a fairly tame track the silvers with 32.5-35. Hope this helps........
Bman's 3XNT is offline
Old 08-02-2009, 06:39 AM
  #3243
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Smile
Maby it was the 6" high speed bumps after the kicker jump! I liked you clearing it. When I did it my Deans conector came undone.... I'm thinking of doing what we talked about 1000w in the rear! That's what I used also Rene to help with the back end being loose when aplying power on exit of a turn.
The back end kicking up was the dam track.... speed bump heaven.
XXXDad is offline
Old 08-02-2009, 07:10 AM
  #3244
Yeah clearing that was fun. Bart kept trying but couldnt clear it. That was with my EPA turned down too 75%.
When I got home I hooked the battery on the charger and it was at 14.8 volts. I couldnt see how many mah I used because my WIFE turned of the charger before I could see it.
Old 08-02-2009, 07:25 AM
  #3245
jeremy reed's Avatar
what system are you running?and what settings to get 20 mins?thanks a bunch
jeremy reed is offline
Old 08-02-2009, 07:51 AM
  #3246
Im running the stock Losi system with the came one my 8E 2.0. Xcelorin ESC, 2100kv motor, 14 tooth pinion and Losi 4 cell 5000mah battery.
Old 08-02-2009, 11:00 AM
  #3247
are you running on a big track or a small one?
Old 08-02-2009, 11:25 AM
  #3248
Medium. Here's a video from last year. The lay out has changed now with more jumps. http://www.youtube.com/watch?v=QZnZzJSbSR8
Disclaimer- I was not driving in the video.
Old 08-02-2009, 12:37 PM
  #3249
Trader Rating: 28 (100%+)
So how much punch did you have with the Losi lipo? I had one of the SMC cmax green wrap lipos...Not a big fan of the non hard case.. I am torn between the Losi and a Thunder Power, but not a fan of the 90 dollar difference in the two. Also has anyone tried a 1700 motor with the losi system yet?
omaha_racing is offline
Old 08-02-2009, 01:51 PM
  #3250
I think the Losi pack has plenty of punch but Im probably going to try a Zippy pack next.
Im going to try a 5cell 5000mah zippy next. They are cheap and only weigh 20 grams more than the Losi battery.
Old 08-02-2009, 05:20 PM
  #3251
littlejohn's Avatar
I own all 3 brands of Lipos, and I can categorically say "stay away from the Losi lipos"
They are overpriced for what they are. The Thunder Power packs or Fantom Racing) packs are what you're after if you want hardcase 4s lipos.
SMC's are good but QA isn't quite as good as TP/Fantom. The TP cells are very tightly matched and have lots of punch.
littlejohn is offline
Old 08-02-2009, 05:30 PM
  #3252
Our track is bumpy and big jumps. Pretty much SX style track. I could try the silvers, but even the greens seem softer than I like. I'm guessing with the nitros you can run really soft and not notice all the chassis slapping because of the engine noise.
GO-RIDE.com is offline
Old 08-02-2009, 06:13 PM
  #3253
I quess that makes sense since I own a TP charger. I gave my Losi charger to a friend, so would not have a way to balance charge it. Are the Fantom's the same thing?
Old 08-02-2009, 07:15 PM
  #3254
littlejohn's Avatar
Fantom lipos like Losi's use the TP TAPS for balancing.
Old 08-02-2009, 07:20 PM
  #3255
When did TP and Losi start to use the same balancing taps? I have a 2 cell losi and a 2 cell TP and they DO NOT have the same taps!
