Losi 1/8 8ight E 4wd Thread >
Old 07-26-2009, 04:05 PM
  #3166
yfzracer912's Avatar
Ok thanks I wasnt sure what size in needed.
yfzracer912 is offline
Old 07-26-2009, 04:53 PM
  #3167
vannon's Avatar
I managed to get it going on the street, and it sounds better now. I managed to lose a wheel nut, but luckily found it.
The inner rear tire seem to lift a little when I do a sharp turn on the pavement. I think the shocks were too stiff.
It is a pleasure to drive it - it was screaming up and down my street.
Originally Posted by Jube View Post
Sounds like your gear mesh is too tight.
vannon is offline
Old 07-26-2009, 07:06 PM
  #3168
jeremy reed's Avatar
does anyone have a clue if losi will get some firmware where you can use the low timing option and initial acceleration option again without the cogging?also ,is there a thread about this system?
jeremy reed is offline
Old 07-26-2009, 07:25 PM
  #3169
dangerwr's Avatar
Originally Posted by yfzracer912 View Post
Can anyone tell me what hex driver I need for my 8ight 2.0? I bought a kit used and didnt get any tools with it. And my current tool kit is metric. Thanks
You will need the following drivers:
0.50"
1/16"
5/54"
3/32"
dangerwr is offline
Old 07-26-2009, 10:35 PM
  #3170
Trader Rating: 49 (100%+)
hey I have broken two different fans now on my losi esc. What is a good upgraded one you guys are using?
illeagle is offline
Old 07-27-2009, 12:43 AM
  #3171
bradfox2's Avatar
0.50"
1/16"
5/54"
3/32"
IIRC that should be 5/64" not 5/54"
bradfox2 is offline
Old 07-27-2009, 05:32 AM
  #3172
Ok thanks guys I just ordered a kit!
Old 07-27-2009, 06:30 AM
  #3173
brofroe's Avatar
Trader Rating: 20 (100%+)
I don't have losi ESC but I have never been able to keep fans on my CC ESC's. I just got the JConcepts body and mounted the esc in the air stream. This weekend it ran 155F after 20 mins of running with no fan. Thats with air temps in the mid 90s.
brofroe is offline
Old 07-27-2009, 10:07 AM
  #3174
Trader Rating: 18 (100%+)
I really like my 2.0 nitro but Im sick of nitro. What do I need to do to get a 2.0E to go 20 min? No Im not the smoothest but I dont drive punched.
Besides servo, battery and reciever what else do I need? Does it come with pinions?
Any links to the Zippy batteries that I need?
infanterene is offline
Old 07-27-2009, 11:45 AM
  #3175
brofroe's Avatar
R u wanting 2 convert yur existing truck or buy a E RTR?
brofroe is offline
Old 07-27-2009, 12:49 PM
  #3176
Should have been more specific. I just bought a new 8E 2.0
Old 07-27-2009, 01:26 PM
  #3177
Integra's Avatar
zippy's come from only one place...google them and you'll find em
as for which battery.....it all depends on what KV motor you have and what set-up you want to run....a 5cell set-up will be heavier then a 4 cell But you might have a hard time making a full 20 min without goin over 5000mah on the pack....is it critical to make 20 min ?
Integra is offline
Old 07-27-2009, 01:31 PM
  #3178
Jube's Avatar
Trader Rating: 43 (100%+)
5s is not any heavier than 4s. If you do mah for mah the ya but that is not needed when going to a higher voltage.
Jube is offline
Old 07-27-2009, 01:49 PM
  #3179
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up
Rene.. Sweet! Go with the Drake setup and a 4 cell Batt. gear 14/45 for Mills and Coral Springs! If you need more info PM me!
XXXDad is offline
Old 07-27-2009, 01:55 PM
  #3180
Integra's Avatar
where are these light 5cells i keep hearing about ?
Integra is offline
