Losi 1/8 8ight E 4wd Thread
#3076
The same part number but they are different. The 2.0 is slightly longer to accommodate the 4mm longer chassis. Also, the 2.0 body is a little longer sides so it covers the side guards better. Lastly, the rear portion is flat so the body clip can be removed with reasonable force. Cheers!
#3077
2.0 is only 2mm longer.
#3083
Those, I hear, may help. Proper gearing is going to be your best defense. It is getting hot here in CO and my temps are getting up there. I am looking to perform a body modification for better airflow. My motor, a NEU, has a finned can which essentially functions as a heat sink. I have seen that there is a fan you can also install on your Losi heat sink.
#3084
Who makes the fan for the esc?? I have not had good luck with fans on my 10th scale esc, but it also had other issues. It ran close to the 220 mark today... I am a nitro guy converted to electric, so I dont have a clue where to gear the motor. Also I was running my old nitro body, so that may also have something to do with the temp.
#3085
Yeah, the 1st thing I would do is get the e-body just to eliminate that variable. What is your current gearing, motor, and battery setup?
A lot of Nitro guys do have the tendency to "goose" the throttle often. Nitro guys get kinda mad but I call it "Nitro finger" and this too will not help the heat situ. Smooth is key with the e-buggy.
Let me know you setup and order the heat sink in the mean time . . .
#3086
You need to gear that at 15/45. I don't know what spur your conversion came with. That will get it close to optimum RPM's. The temp should not be nearly that high. I run the heat sink on my Xcelorin motor. Did you turn the EPA down and how much? Is your fan on when you turn the car on? The ESC runs it all the time so it should be on as soon as you flip the switch.
I have two E buggy bodies.. You can borrow my black one.
Ben
#3087
Tim,
Ben
Ben
#3090
Will the 1.0 shell physically fit then?
