Losi 1/8 8ight E 4wd Thread >
Old 08-28-2008, 09:55 AM
  #16
gacjr0's Avatar
Trader Rating: 15 (100%+)
Originally Posted by UPSguy View Post
The info on RedRC and here says 2100kv motor but the pictures and Losi's website show 1700kv. Can someone explain to an electic newbie the difference please?
1700kv= 1700 rpm per volt
2100kv = 2100 rpm per volt
They offer different motors for different uses (good).
It seems most people will run 4 cell lipo which will give 16.8-13 volts throughout a run. So multiply the motor kv by the battery voltage and you get 30,000+ rpm. Thats a lot like the effective rpm of a nitro and will almost certainly have more punch.
gacjr0 is offline
Old 08-28-2008, 09:58 AM
  #17
badassrevo's Avatar
the 1700 will work better with 5s and the 2100 will work with both 4s and 5s
badassrevo is offline
Old 08-28-2008, 11:35 AM
  #18
tyhodge07's Avatar
Originally Posted by air8 View Post
Anyone know who's producing the electronics for this buggy?
And did I hear right, that there is a limited production at first?
i heard it was hacker or novak
tyhodge07 is offline
Old 08-28-2008, 11:38 AM
  #19
rocketron's Avatar
Trader Rating: 16 (100%+)
neither are true
rocketron is offline
Old 08-28-2008, 11:40 AM
  #20
UK.hardcore's Avatar
Feigao?
UK.hardcore is online now
Old 08-28-2008, 11:58 AM
  #21
jhautz's Avatar
Trader Rating: 86 (100%+)
Originally Posted by dr_hfuhuhurr View Post
Honestly I loathe the thought of these running at our local track on electric days. These things will demolish the current 2wd, and 4wd cars in a crash. I've seen it happen already.
I almost agree. I think that Nitro night and Electric night will eventually go by the wayside in favor of 1/10 night and 1/8 night.
Originally Posted by UK.hardcore View Post
Feigao?
Lets hope not....
Do we know who makes their 1/10 stuff? probably the same source.
jhautz is offline
Old 08-28-2008, 02:03 PM
  #22
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
God, i hope not. Hacker don't make 4 pole motors, so don't think it would be
Feigao?
Drift_Buggy is offline
Old 08-28-2008, 02:13 PM
  #23
Originally Posted by porkey View Post
the motor is only a 1700 kv its not that big of a motor
and the biggest one they have is a 2100 kv i think
Do you know this for sure? They say 2100kv on Losi's site
01. PRE-INSTALLED XCELORIN 1/8-SCALE 2100KV SENSORLESS BRUSHLESS MOTOR
02. 4MM MOTOR MOUNTING SCREWS
03. SECURE, HARD-MOUNT XCELORIN ELECTRONIC SPEED CONTROL (ESC) WITH RUBBER SHOCK ABSORBERS
04. LARGE ESC HEAT SINK WITH FAN
05. 4MM THICK MACHINED AND HARD ANODIZED ALUMINUM CHASSIS PLATE
06. UNIQUE NARROW CHASSIS CONFIGURATION FOR QUICKER HANDLING
07. OVERSIZED SHOCKS WITH THREADED HARD ANODIZED SHOCK BODIES
08. SEALED FRONT AND REAR DIFFERENTIAL HOUSINGS KEEP DIRT OUT OF THE GEARS
09. ZERO BUMP STEER DESIGN WITH ADJUSTABLE ACKERMAN
10. CAPTURED HINGE PINS REQUIRE NO RETAINING CLIPS
11. MACHINED PREMIUM ALUMINUM 5MM THICK ALLOY SHOCK TOWERS
12. MOLDED LIPO BATTERY TRAY WITH HOOK AND LOOP STRAPS THAT CAN
ACCOMMODATE A 3S TO 5S LIPO BATTERY
13. ADJUSTABLE ALUMINUM MOTOR MOUNT
14. PRE-GLUED XBT PIN TIRES AND DISH RACING WHEELS
The 8IGHT-E Race Roller features Losi’s superior 1/8-scale Xcelorin Sensorless Brushless Power System. The fully programmable, high-output electronic speed control (ESC) can handle a 3-5-cell LiPo battery pack, and offers precise throttle and braking control. The 2100Kv brushless motor requires virtually no maintenance, while offering unmatched efficiency and speed designed for 1/8-scale racing. Additionally, the ESC offers tons of programming options, including adjustable throttle limits, selectable user profiles, and much more using the Quick Programming Card or personal pc programming software.
Features
* Pre-installed Xcelorin 1/8-scale Brushless System with 2100Kv Sensorless motor w/5mm shaft
Old 08-28-2008, 02:31 PM
  #24
Old 08-28-2008, 02:42 PM
  #25
kufman's Avatar
Where does it say 4-pole? I like 4-pole motors, I just didn't see it mentioned anywhere.
kufman is offline
Old 08-28-2008, 02:48 PM
  #26
http://www.phpbbplanet.com/losi8ight...orum=losi8ight
1st Post under Features
Old 08-28-2008, 02:53 PM
  #27
Rfury's Avatar
How much runtime could we expect from the 5000mah 4S packs that Losi sells?
I am selling my 10th scale electrics and getting one of these as soon as I can. If not one of these then I will get one of the kits, conversions from Losi and one of there ESC/Motor combos and build it myself.
Rfury is offline
Old 08-28-2008, 02:58 PM
  #28
Probably 15-20 mins, maybe a drop longer depending on gearing and driving style.
pullinteef is offline
  #29
porkey's Avatar
it would depend one the motor like a 2100 kv about 18 min
a few guys that have an 1/8 scale they run 6000 and get 20 i think
i havent seen lately u can get a good run time on a 5000 4s
porkey is offline
Old 08-28-2008, 03:02 PM
  #30
Rfury's Avatar
They run 20 min mains in my area. I am one of those guys that don't use the brakes much. I coast into corners and roll on the power off the corner. I try to use my left index finger to control wheel spin instead of using the slipper to do it. If 5000mah will get me 20 mins that that is the what I will get. If not I will save up the extra bucks and get a 8000 from Maxamps.
Rfury is offline
