Losi 1/8 8ight E 4wd Thread
#2971
im getting about 16-17 minutes with no drag brake,the 15t pinion,and the losi 14.8v 4s battery.i would also highly recomend the losi heatsinc.i live in the fire hole called south alabama and its been about 98-100 deg and very very humid and i was running 180-190 deg.when i put the heatsinc on it went down to 160.that thing is a motor saver for sure.the best $30 you will spend.
#2974
thanks for the reply's guys cheer's.
ok lets talk batteries. what would you recomend i get? im looking to get at least 20 mins for a 20 min main i would go for 30 mins but i know that would be pushing it. so what batteries should i get and why?
also what charger should i get too? based on the fact ill be probably using a losi 8 E 2.0 with xcelorin 2100 kv.
im thinking go as max as i can but maybe maximum will be too much?
i guess you need to compromise between speed and runtime.
any help much appreciated. thanks again guys.
#2975
edit
#2976
These: Zippy 4S 5000 25C
And a couple of these:Mulitplex LN-5014
Oh, and a couple of these: Astro Blinky
#2977
on our track,which is big,if i run the 15t with no drag i get about 15-17 min with the losi 4s batt.its expensive but worth it.with the 16t and no drag being conservative i think i could get 20.to get it for sure you may want to try going to a 6000 or 6500,like a max amps.once agin expensive but worth it.AND GUYS CHECK THIS OUT,WATCH USING THE SMALL CONNECTERS LIKE THE DEANS,KEEP THE BIG EC5 AND PUT THE MATE TO IT ON YOUR BATT.USE A BATT WITH THE BIG GUAGE WIRES LIKE THE LOSI COMES WITH.I THINK YOU WILL FIND IN THE END OF THIS WHOLE BAD MOTOR/ESC THING THAT THAT IS GONNA BE THE BLAME.thats my theory,testing and watching others do and not do what i say has proven right so far.we will see.once agian this is my theory and not wanting to start a connecter storm argument.lol
#2978
Jeremy..
I agree with you 100% on the connector issue. Funneling the current through a 70amp connector is rediculous in my opinion. I have 10awg wire on my battery that is rated much higher than 70 amps. I have been running EC5 connectors since day one. One thing you could run better is a 6mm bullet connector. Just the specs on the electronics should show that a 70amp connector just isn't enough.
Just my .02 on the issue.... Mine could blow up tomorrow.
#2979
So you get more runtime with a higher tooth pinion? How is that? Wouldn't that lower your gear ratio, and therefore increase the amp draw?
#2981
Here's what I use:
Using a charger that can actually balance during charging will provide MUCH better results. 8th electric works the batteries hard
#2982
Do you attempt to balance a 4S or more battery using a battery maintenance device? (Blinky or other) If the battery happens to get out of balance it very easily could take 6+ hours or longer for these devices to balance a battery. Using these devices typically WILL NOT balance a battery in the short time it takes to recharge.
#2983
#2984
#2985
