Losi 1/8 8ight E 4wd Thread >
Old 06-26-2009, 08:28 AM
  #2956
Trader Rating: 49 (100%+)
Ya mine did the same thing. It ended up being the speed control went bad. I sent it into horizon and they are sending me a replacement. Lights worked and nothing was hot, it just stopped. I had a second motor so I tried it and that one didnt work either. Then I borrowed and esc from a friend and the original motor worked with it.
illeagle is offline
Old 06-27-2009, 12:17 PM
  #2957
Default transponder mounting
Hey you guys need some ideas on how to mount the transponder on the 8E? Post pics if possible.
Jake
Bubonic-X is offline
Old 06-27-2009, 12:45 PM
  #2958
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
XXXDad is offline
Old 06-27-2009, 02:21 PM
  #2959
Glen thanks thats exactly where i was thinking except im gonna use lexan
Old 06-28-2009, 08:44 PM
  #2960
dangerwr's Avatar
Jake
Jake,
I use a personal transponder that I Velcro to the top of the '8' directly above the spur. Works great and I can swap it out during races for my 10th scale. I have yet to have a problem!
dangerwr is offline
Old 06-28-2009, 08:55 PM
  #2961
jeremy reed's Avatar
THATS EXACTLY WHAT I DO.WORKS GREAT
jeremy reed is offline
Old 06-29-2009, 04:47 AM
  #2962
downunder23's Avatar
hi guys. id love to read through this thread but it looks massive and dont have the time to do so, so i thought i would just chime in and see what happens hope you guys dont mind.
i am looking into going brushless i currently race nitro buggy (xray xb808)
but am very interested in going brushless or having both.
i will be seriously considering the losi eight-E 2.0 kit with the xceleron 2100kv motor and esc.
but would like to know a few things first so i am wondering if you guys could help?
firstly is the motor the 2100kv included in kit strong and fast enough for 1/8 scale racing vs the nitro's? and what is the maximum voltage i can put into this motor esc combo that comes with the kit with out it getting too hot?
also if i was to buy the losi 8 E 2.0 with the xcelorin 2100kv motor with speedo would i be able to put the 2400kv motor that is on losi's website sold seperately,and still and still be able to use the original esc that came with the kit or would i have to upgrade that too?
downunder23 is offline
Old 06-29-2009, 07:26 AM
  #2963
I HAVE HAD MINE FOR QUITE A WHILE NOW(LOSI XCELORIN 2100) AND HAD NO ISSUES WHAT SO EVER.SOME GUYS HAVE BUT THEY HAVE ALSO HAD PROBS WITH MAMBA AND TEKIN.THIS IS NEW AND WILL TAKE A LITTLE TIME TO WORK THE BUGS OUT,BUT I THINK THE NEWER UNITS ARE FINE.THE 2100 IS A BEAST AND I CAN PULL EASILY AWAY FROM A VSPEC AT OUR LOCAL TRACK DOWN THE LONG STRAIGHT.PLENTY OF POWER.YES I BELIEVE YOU CAN USE THAT MOTOR YOU ARE REFERING TOO BUT IF YOU HAVE THE PLEASANT EXPERIENCE WITH YOURS THAT I HAVE ,YOU WONT WANT TOO.I THINK THIS IS A GREAT SET-UP AS LONG AS YOU GET ONE OF THE NEWER UNITS.THEY ALSO ARE ALREADY UP-DATED WITH THE LATEST FIRMWARE.I RECOMMEND THE 2.0 W/2100 100%.JMO FROM EXPERIENCE
Old 06-29-2009, 12:44 PM
  #2964
rocketron's Avatar
Trader Rating: 16 (100%+)
the 2100 is plenty quick for racing, and on the esc make sure it has the latest firmware. you can install the 2400 motor and use the same esc but will suggest a smaller pinion
rocketron is offline
Old 06-29-2009, 03:14 PM
  #2965
DaveG28's Avatar
Trader Rating: 65 (100%+)
I'm liking mine too, thumbs up from me, though ongest run has been 11 mins so far, how has everyone found its coped with the heat on kit gearing??
DaveG28 is offline
Old 06-29-2009, 03:49 PM
  #2966
badassrevo's Avatar
Jake
When I ran a Losi, I just put it inside the radio box with my reciever.
badassrevo is offline
Old 06-29-2009, 03:51 PM
  #2967
warpig's Avatar
+1...
warpig is offline
Old 06-29-2009, 04:26 PM
  #2968
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I did a fifteen minute main with a 13 and stock spur. It was about 75-80 outside and the motor temp was around 170 F.
+1
Bman's 3XNT is offline
Old 06-29-2009, 04:28 PM
  #2969
I saw a Losi and a brand new Tekin go up this weekend. The Tekin only had a battery through it. The Losi was a few months old. Two different people too!
Old 06-29-2009, 04:36 PM
  #2970
TeckLancer's Avatar
+1
TeckLancer is offline
