Losi 1/8 8ight E 4wd Thread >
Old 04-11-2009, 11:19 AM
  #2386
Ronda Drake's Avatar
My experience racing the Tekno/Mugen conversion kit was awesome! I got the car 2 days before the Silver State race in Vegas. I had very little experience with electric 1/8th scale. I have to say Daniel from Tekno has an excellent product that I would recommend to all my friends. The clutch is phenomenal! I will say that the with all the heavy electronics it puts a stress on the car. I broke a rear plastic block on the car when I landed wrong off a jump. That's just the nature of racing. Check out the results on liverc.com
Ronda
Ronda Drake is offline
Old 04-11-2009, 03:20 PM
  #2387
warpig's Avatar
Yes, I am impressed with the Xcelorin system with the 2100kv motor. It's super smooth and has more power than I need. I have my EPA at 82% on throttle and I'm not sure on brake (I know I turned it down though). It is faster than any nitro I've ever ran and easier to drive. I hasn't gotten hot and hasn't flinched even once.
I am running the latest firmware as well. I used the losi programming card at the track and it is super easy to use and very quick to program. It takes the new program in like half a second and it's ready to go.
Ben
warpig is offline
Old 04-15-2009, 04:21 AM
  #2388
DaveG28's Avatar
Trader Rating: 65 (100%+)
Has anyone used the losi recommended 4S lipo? What is power/runtime like? Also what balance connector does it have?
DaveG28 is offline
Old 04-15-2009, 05:51 AM
  #2389
I'm planning on running 4S 4000 packs...........Should I get the CC with 2200kv or the 2650kv?
tfa8rva is offline
Old 04-15-2009, 07:43 AM
  #2390
R40Victim's Avatar
I have one, and ended up replacing the balance connector with one that fits the blinky. Now I can balance ALL my packs with one device. The connector that came on mine was a PITA, and because of it, I thought there was something wrong with my charger or my battery. I ended up breaking the hard case open so I could figure out what's going on. It's works fine now with the new connector.
As for power and run time. It will run for 20-23 minutes in my 8ight E. It performs exactly the same as the 4900 20C rhino pack I got. 1 cell was always a little low, and it has begun to puff. I'm pretty good with my batteries, always keeping them charged, balanced and never running them down too low. So if it goes poof, it wasn't due to poor care.
R40Victim is offline
Old 04-15-2009, 08:03 AM
  #2391
F N CUDA's Avatar
Trader Rating: 34 (100%+)
R40,
I'm runnin a Blinky too and when I got it we just tweeked a couple pins on it to fit the Losi balance plug and it seems to be workin fine.
I was told by a Losi dude that the Blinky really doesn't do a great job at actually fully balancing the cells and that after longtime use it really needs to be balance charged with a quality charger and that it might take quite a while to get them dialed.
F N CUDA is offline
Old 04-15-2009, 08:08 AM
  #2392
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by F N CUDA View Post
R40,
The BLINKY does a good job balancing BUT it is a MAINTENANCE device and in most cases will NOT balance a battery pack during the length of time a charge will take. If a battery pack gets out of balance a device like the blinky can take 6 hours and possibly up to 24 to truely balance the cells. This is not bad but be aware that this type of device does NOT replace a balance charger.
Losi has a really nice maintenance device available now as well with connectors for most batteries included ... LOSB9625
rocketron is offline
Old 04-15-2009, 08:22 AM
  #2393
R40Victim's Avatar
Oh yeah, I know that. But up until I replaced the connector, I couldn't balance my packs at all! I do end up leaving it on there for hours sometimes, but typically just between charges, or at the end of a race day.
Old 04-15-2009, 08:46 AM
  #2394
Integra's Avatar
Ive been told the blinky will do its job in the time it takes to charge and No more.
Integra is offline
Old 04-15-2009, 09:45 AM
  #2395
F N CUDA's Avatar
Thanks Ron,
Wasn't exactly sure how that works.
Maybe see you tonite? Dust it off and lay it down.
F N CUDA is offline
Old 04-15-2009, 10:54 AM
  #2396
DaveG28's Avatar
Sorry guys, what pin type is it? I've got a Bantam BC6 charger and need to know which board I would need for it to balance the Losi battery??
Also, what other comparable (4S, 5000 or more mah, hard case, same size) cells are out there?
DaveG28 is offline
Old 04-15-2009, 10:56 AM
  #2397
R40Victim's Avatar
Not many, but more will become available. So far, they're just too darn expensive, so we've been using these:
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
Old 04-15-2009, 11:00 AM
  #2398
Dan
Dan's Avatar
Trader Rating: 68 (100%+)
Check out the 4S lipo coming out from SMC. It will be available with the option for hardcase and is a 40C pack. I think its a 5200 or 5400mah pack but I forget... Will run for the same price as the Losi pack and probably better cells to boot too.
Dan is offline
Old 04-15-2009, 11:19 AM
  #2399
DaveG28's Avatar
Found an answer, it's thunderpower connectors apparently! All I need is the relevant board and the BC6 will balance charge it!
So, am looking at getting the eight 2.0e race roller and the losi battery as an electric 8th, any reason to avoid or am I all good?
Will the included esc protect my receiver from the extra voltage ok?
DaveG28 is offline
Old 04-15-2009, 11:53 AM
  #2400
warpig's Avatar
I am sure the losi battery works fine but I did not choose it because it is 628g and the SMC is 502g and is a much nicer battery for less money. Just a thought.
warpig is offline
