Losi 1/8 8ight E 4wd Thread >
Old 03-30-2009, 02:16 PM
  #2221
warpig's Avatar
Originally Posted by johnnyr135 View Post
Hi guys I have a question I am a newbie and you have all helped me out in the past. I Bought a Slash and a stampede and had so much fun I decided I wanted to try racing. Well I bought a Losi E-Eight 2.0
and I have a few questions. When I press the throttle more times then not the gear on the motor and the gear on the center diff will make clicking noises and the car will not engage then all of a sudden it does and it takes off. This takes longer in reverse then in forward, in forward if I ease up on it and then punch it the car will grab and take off. I adjusted the gears like I did it the other cars with a piece of paper between them but these are straight cut steel gears I was wondering if I should be doing something else or if anyone else is having this problem? Thank you
Attachment 435230
Could the motor be cogging?
warpig is offline
Old 03-30-2009, 02:38 PM
  #2222
What does cogging mean? Thank you for the help
johnnyr135 is offline
Old 03-30-2009, 02:43 PM
  #2223
warpig's Avatar
This is from Castlecreations. The ones who make the mamba systems.
5. My vehicle acts like it has "turbo lag" (poor acceleration/punch for the first few feet or yards, and then it "kicks in").
Make sure you're using high quality batteries, and a battery connector capable of high amp flow (75A minimum!)…we recommend our 6.5mm CC Bullets, Deans Ultra connectors, or the Traxxas TRX connectors. This behavior is very typical of a battery pack that is having difficulty providing the power your vehicle/system requires for top performance. The faster the top speed of the system, and the more traction available, the harder the batteries have to work to accelerate the car.
warpig is offline
Old 03-30-2009, 02:45 PM
  #2224
warpig's Avatar
What kind of batteries and what connectors and wires are you running?
warpig is offline
Old 03-30-2009, 03:56 PM
  #2225
R40Victim's Avatar
It means the motor isn't getting enough energy to initiate movement. You'll have to squeeze your trigger harder. Also, try updating your firmware to the latest and greatest. Mine has the newest stuff, and it works MUCH BETTER. It's allot smoother, and the brakes are easier to deal with.
R40Victim is offline
Old 03-30-2009, 04:49 PM
  #2226
bradfox2's Avatar
Attachment 435230
just set the gear mesh so there is a tiny bit of play between the gears.
that is a 1.0 btw too. Just saying so someone else doesnt correct you at the track or something.
bradfox2 is offline
Old 03-30-2009, 05:17 PM
  #2227
Integra's Avatar
Originally Posted by Juan Valdez View Post
Hey guys, got a question. I was going through my car and have the rear gear box off. When I spun the input, it was very notchy. For comparison, my front gear box is perfectly smooth and free spinning. With the rear input CVD off, the rear pinion gear/input shaft has no slop at all. You can not push it in or pull it out. When I disassembled everything, it all looks okay and the bearings are all smooth. I think the gear mesh is just very, very tight. Is this normal? Does the rear gear box need to break in more? I have between 1 and 1.5 hours of run time on the car, and the rear gear box has not improved. Does it just need more time, or is this something unusual?
My car is a 1.0, so you can not shim the rear diff. Would it be worth it to upgrade to the 2.0 rear gear box set so I can shim my gear mesh? Any help would be appreciated. I'm new this shaft drive thing. All my TC's are belt drive so I've never had to deal with bevel gear mesh before. Thanks!
You can shim the 1.0 diff.....Not as much as the 2.0...but all you have to do is use 8x10 or 8x12 basically any 8mm shim and stick it Under the Flanged bearing...obviously you want to make the mesh a little looser...so install it under the Ring Gear side of the cup and when installing the diff you might need to give it a little force.....its nothing drastic...you will hear/feel the diff "click" into place..and the mesh should be Golden....I did this on Both my 1.0 B and T for the fact i Did Not like the whole "diff breakin" I shim them Smooth right outta the box and have NEVER had a R+P fail.
thickest shim you can use is a .3 you will prolly need .1 or .2
Kyosho makes a nice 8mm shim kit.
http://carolinasrc.com/Webstore/Scri...idproduct=1795
Dont forget about the coupons as well...saving a buck or 2 where you can helps.
$75.00 - 149.99 = $5.00 RCMAR95
$150.00 - 249.99 = $12.50 RCMAR912
$250.00 - 799.99 = $25.00 RCMAR925
$800.00 + = $75.00 RCMAR975
Integra is offline
Old 03-31-2009, 12:41 PM
  #2228
warpig's Avatar
Not to make everyone have a nasty mess in their pants but the Losi 8ight-E 2.0 is IN STOCK at horizon right now. Bam! Looks like I'll have a car this week and I lost a double cheeseburger to Matt. GRR! I mean.. YAY! Um.. wait a sec.. bitter sweet loss/victory!
warpig is offline
Old 03-31-2009, 12:50 PM
  #2229
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Ran my 8ight E 1.0 Sunday with the heavier oils.
Still dialed and less chassis slappin the ground.
Feels like it's easier to drive fast thru the big jumps.
F N CUDA is offline
Old 03-31-2009, 12:54 PM
  #2230
Trader Rating: 17 (95%+)
What are people running fluid wise in the Diffs? In my 8T-e, I've got 5/10/2
JGruber is offline
Old 03-31-2009, 01:27 PM
  #2231
R40Victim's Avatar
I'm running 3/5/2 in my truggy. It handles awesome, but when I hit the breaks at high speed, it almost flips forward, the rear tires come OFF THE GROUND and they actually turn, BACKWARDS! I may have to add a throttle servo back in, just to minimize that issue. I just rebuilt the rear diff a few weeks ago, and it already has a click.
Old 03-31-2009, 01:36 PM
  #2232
Matt Howard's Avatar
Matt Howard is offline
Old 03-31-2009, 01:39 PM
  #2233
HobbyPLEX's Avatar
Ben, I just got a call today and your 8E 2.0 will be here Thursday.
HobbyPLEX is offline
Old 03-31-2009, 01:57 PM
  #2234
warpig's Avatar
I have to wash my jeans... That is so RAD! I will call before heading up for sure though.. haha Thank you!
warpig is offline
Old 03-31-2009, 03:10 PM
  #2235
Jeff Crosson's Avatar
Two of them, right? I'm paying for mine when I pick it up.
Jeff Crosson is offline
