Losi 1/8 8ight E 4wd Thread >
Old 02-07-2009, 10:18 PM
  #1591
I've recently discovered that stiffer springs work really well. Apparently it makes sense as the car is heavier, lol. The car doesn't often scrape the front of jumps anymore and doesn't bottom out as hard. It floats through rough sections securely. It basically now has the rebound it should have. Handling feels planted with good turn-in.
Basically running the Truhe setup with green springs front and black in rear. Oh and 5/10/2 in the diffs. I tried 7k in the center but the car lost its punch and just ballooned the front tires all day.
deskwarmer is offline
Old 02-07-2009, 11:03 PM
  #1592
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Ya I switched to black springs in rear with 54/35 setup. Works real well. I had green springs in rear which made car push off-power. So ya works great.
BuggyKing is offline
Old 02-07-2009, 11:57 PM
  #1593
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Turbo Joe
I have it turned down some, but that's not really a good option IMO. I think it's better to just use a slower motor and all the available throttle resolution.
I really doubt that the radio re-slopes the throttle curve...I bet it just clips the top end (AKA: "end point adjustment"). It's gonna be just as touchy everywhere, you just don't get to WOT.
Are there any other motor brands that you can use with a Losi ESC?
Turbo - you can adjust the curve between neutral and WOT and from neutral to Full Brake. There is a curve for each side - no end point changes unless your doing it on the transmitter. Also you can reduce throttle through setup if you like.
The 4 pole design motors Losi/Neu are tough to handle on the smaller indoor tracks.
You can use any Sensorless motor with the Losi esc.
rocketron is offline
Old 02-08-2009, 12:40 AM
  #1594
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
So just make the throttle curve top out at half-way (or whatever) in the software and leave the TX at full EPA value? That should work.
I *was* going to go out to Rev today...but obviously that didn't go so well...
I'm still thinkin' 1300...LOL...
Turbo Joe is offline
Old 02-08-2009, 07:32 AM
  #1595
Integra's Avatar
Originally Posted by littlejohn
some more..
awesome paint John.....i saw a shell like that forever ago and kinda always wanted something similar.
Integra is offline
Old 02-08-2009, 01:00 PM
  #1596
littlejohn's Avatar
Originally Posted by rhino420
looks good john !!! like the paint job too !!
Thanks...
Thanks... it's surprisingly easy to do..
I need to say thanks to shark413 for the drill & tap of the motor idea and colin8ight-e for the layout ideas... Makes for a very "factory" look.
littlejohn is offline
Old 02-08-2009, 01:17 PM
  #1597
Questions?? Smart Diff in an 8ight-E
Is it possible to run the Smart diff in the center position on the electric conversion? It seems to me like it would need to work in reverse to function properly since the electric diff is turned around backwards. Any techs out there know what the skinny is on this one? Maybe you can just use the front Smart Diff by itself to get a similar result. Anybody?
edfmaniac is offline
Old 02-08-2009, 01:55 PM
  #1598
I am not sure smart diffs will work in electric unless you use mechanical brakes...any thoughts on this?
Thopper is offline
Old 02-08-2009, 03:52 PM
  #1599
rocketron's Avatar
the Smart Diff in the center is used often to make the car rotate better. They work in both Nitro and Electric buggy's / truggy's
Old 02-08-2009, 04:06 PM
  #1600
dangerwr's Avatar
Default Losi center smart diff
I saw you can buy the smart diffs now. Anybody use the center on an 8ight-e yet? I am sure it will be real nice .
dangerwr is offline
Old 02-08-2009, 04:09 PM
  #1601
teeforb's Avatar
Trader Rating: 94 (100%+)
what's the purpose of the smart diff? $89 a diff is pretty expensive.
teeforb is offline
Old 02-08-2009, 04:25 PM
  #1602
dangerwr's Avatar
The idea, similar to a torsen diff I believe, is to transfer power F/R under acceleration by essentially engages the diff and "locks" it. When you let off power the springs in the smart diff force it "open" to allow for improved cornering.
I have the spec sheet but am not able to post it here since it is too large I guess .
dangerwr is offline
Old 02-08-2009, 05:01 PM
  #1603
Shark413's Avatar
Trader Rating: 24 (100%+)
You think the Losi Smart Diff is expensive, check out the Fioroni diff, $200+.
Shark413 is offline
Old 02-08-2009, 05:06 PM
  #1604
Shark413's Avatar
Thanks...
Glad to share the knowledge and especially glad to hear someone found it useful. I really think the 4mm screws add a lot of strength to the conversion.
Shark413 is offline
Old 02-08-2009, 06:11 PM
  #1605
My understanding of the smart diff is that it disengages when there is no power to it, how would you get electric brake if it is free rolling?
Thopper is offline
