Old 08-26-2008, 05:49 PM   #1
Default Upper temp limit for brushed motor?
What is the recommended upper temperature limit for a brushed mod motor?
Thanks!
haulin79 is offline   Reply With Quote
Old 08-26-2008, 06:10 PM   #2
T. Thomas's Avatar
Anything above 230ish is getting too hot for any electric motor. The cooler you can keep your motor the better and longer it will last.
T. Thomas is offline   Reply With Quote
Old 08-26-2008, 11:49 PM   #3
BuggyKing's Avatar
Trader Rating: 17 (100%+)
180 degrees is getting hot for a mod motor. It will start burning the copper windings on the armature. Also pull the brushes too, and if they look purple in color that is also an indicated that the motor is running to hot. Now if u pull the car and feel the motor and u can keep ur finger on the can then ur gearing is ok.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 08-26-2008, 11:53 PM   #4
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
+1
RCRat is offline   Reply With Quote
Old 08-27-2008, 12:34 AM   #5
JeromeK99's Avatar
You go over 170 degrees for a brushed motor and your brushes will be toast in one run! 230 degrees and I bet your brushes will unsolder themselves or you will melt a brush spring! Ask some of the on-road guys!
Jerome
JeromeK99 is offline   Reply With Quote
Old 08-27-2008, 12:41 AM   #6
Do you mean 170 F or 170 C ?
Old 08-27-2008, 08:30 AM   #7
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
170 F
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-27-2008, 08:43 AM   #8
tom_chang79's Avatar
+1
Ye-Old Finger Test. I've been using this trick for 15+ years... It's a great method!
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 08-27-2008, 08:55 AM   #9
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
Jerome
not always. I accidently hit 280 on a CO27 a few weeks ago after a 5 min heat. Wrong gearing on my part. I just regeared and ran fine. I might have been lucky but didnt hurt my brushes or springs or solder.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 08-27-2008, 08:59 AM   #10
Briguy's Avatar
I`m sure we all have done that a time or two , sometimes they are fine and sometimes not .
Royal R/C & Hobby
Old 08-27-2008, 09:58 AM   #11
Is the can temp usually lower than the end bell temp? If so, perhaps that is why the solder can melt at the end bell while only measuring 230 F at the can.
From http://www.tpub.com/neets/book4/12n.htm
Melting Point of various electrical solders:
Old 08-27-2008, 10:17 AM   #12
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
All good info, unless you're running a Reedy. Reedy motors have this propensity for running hot; my MVPs did a constant 170F all the time, it's just the way they are. And from what I can tell so far, the new Stockstars and Challengers are the same way.
I've heard that the reason the magnets don't die from the heat is Reedy sources their magnets from a different place than Trinity, and these magnets have a higher tolerance to heat. Whether that's truly the case or not, I'm not positive. But I can say in the 6 or so years I ran MVPs up until now, I never junked one because the magnets went bad. I blew one armature up and had a magnet pop off the side of the can (my fault, skipped the chassis off a curb at the end of my driveway), otherwise I only replaced them when the commutator got too small for any more cuts on a lathe, and they didn't sell armatures separately.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 08-27-2008, 10:26 AM   #13
can temp is always lower then endbell temp. i was taught to temp from can.
Old 08-27-2008, 10:27 AM   #14
Briguy's Avatar
I`ve never had a magnet problem and only problems from an overheated motor were the arm windings .
Royal R/C & Hobby
Old 08-27-2008, 11:00 AM   #15
I run all my motors at 150-160 just to be safe.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Upper temp limit for brushed motor? haulin79 Micro and Mini Scales 1 08-26-2008 10:48 AM
Motor Temp on Brushed Motors? Bohh Rookie Zone 4 08-24-2008 01:28 AM
KOPROPO VFS-1 Competition ESC (No Limit Brushed) vazzo Australia For Sale/Trade 1 08-20-2008 03:51 AM
Novak & LRP No Limit brushed ESCs New In Box! nzdans Australia For Sale/Trade 17 07-19-2007 09:39 PM
esc motor limit ajg Electric On-Road 2 02-12-2004 08:09 PM
