Old 08-27-2008, 05:41 AM   #31
Originally Posted by VVRC View Post
Simple answer......No!
For the past two weeks it has been my sole mission in life to find an LVC that works.....can find one!
People on my site have said the Common Sense R/C unit works with the Slash.
rm25x is offline   Reply With Quote
Old 08-27-2008, 11:19 AM   #32
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Originally Posted by rm25x View Post
Yeah I think I killed one of my lipo's from running it too low in my Slash. The "stop when it starts to loose power" sounds good in theory, but not in real life
Then only run it for the length of a race
Pretty sure most lipos 3200 and up will run for 5 to 7 minutes safely so check your watch and run the snot out of it
Shouldn't be that big of a deal unless you just can't stop driving.
Good lipos are pretty tough, just use your head and you won't run it too low in your Slash like some seem to have done.
Real life still needs common sense.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-27-2008, 11:34 AM   #33
stitchy's Avatar
Anyone wanna be the guinea pig? I've tried the Novak and Liposhield and don't wanna waste any more money on these things...
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 08-27-2008, 12:49 PM   #34
porkey's Avatar
try to charge it discharge it then balance it i did it and it should come back
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 08-27-2008, 01:30 PM   #35
Originally Posted by haulin79 View Post
What does 3D stand for?...As opposed to flying in 2 dimensions?
Originally Posted by shurcooL View Post
Yeah, pretty much. 2D as in mostly going in the same horizontal plane, just turning left and right and changing the elevation by a little. 3D means highly acrobatic flight, with no regard to where the horizontal plane is.
I'm just guessing based on what I've seen. I've heard them refer to 4D flight when the plane has a variable-pitch-prop, meaning it can fly forward or even backwards.
It's just a name though. It's not a precise scientific term.
As shurcool said it is not a scientific term, just name.
Instead of flying like a regular airplane 3D flying looks like something you would never see a real air plane, It mostly refers to hanging the plane verticaly on the prop. A good 3D plane will have a 2:1 thrust ratio and use slow, large diameter props to move a lot of air across enlarged control surfaces.
I have been flying for a long time but it didn't do much for me but 3D got be hooked. I fly all electric and mostly small foamies.
Here is a video that show someone flying normal then some 3D, also it is a ton harder than it looks.
http://www.youtube.com/watch?v=qMrUuRL7vBg
"It's like his brain is running a 64p spur and 48p pinion, sometimes it will engage and work but mostly it just makes a terrible noise"
Stallard is offline   Reply With Quote
Lipo cutoff for a slash T4 Razer Electric Off-Road 3 09-06-2008 09:31 PM
NIB GTB W/ Lipo Cutoff kartermdb R/C Items: For Sale/Trade 0 07-31-2008 03:08 PM
Looking for GTB w/LiPo cutoff Scottrik R/C Items: Wanted to Buy 3 04-16-2008 06:54 AM
GTB w/ lipo cutoff convikt R/C Items: For Sale/Trade 0 02-17-2008 11:04 PM
GTB Lipo cutoff _pilot_ Electric On-Road 15 10-14-2007 09:30 PM
