Old 08-26-2008, 07:15 PM   #31
d16dcoe45's Avatar
Originally Posted by Lenman73 View Post
What is this black box edition T4 you speak of. I am very interested . I can't say as though I am in associated's inner circle so I have heard nothing about this.
Lenman
"black box" isn't a special edition. Its simply the newer B4/T4 FTs starting from maybe nov 07. They are supposed to be the same as the older FT, the only real differences are plastic instead of graphite chassis (I don't think anyone liked the graphite chassis), rubber instead of teflon bearings, slightly different shock ends,--the shock quality has gone down hill--newer ti-ni shafts aren't as durable nor as smooth, the black rubber bearings aren't very good IMO, and the overall quality has taken a hit on the black box stuff. They are still awesome cars and its still totally worth getting a new T4, but I don't think the quality is the same as on the older "sealed" kits. The black boxes are still sealed with the small associated sticker but they got rid of the saran wrap covering.
I also think the newer B4s come with the b44 rear wheels--they have the dish like a Losi wheel instead of the old recess for the nut in the center.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 08-27-2008, 06:47 AM   #32
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
Originally Posted by d16dcoe45 View Post
"They are supposed to be the same as the older FT, the only real differences are plastic instead of graphite chassis (I don't think anyone liked the graphite chassis)
I do!
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 08-27-2008, 09:27 AM   #33
Heathen's Avatar
I have noticed the quality of some of the companies has gone down hill since the RTR's started taking over the hobby. For instance the new XXXtcr a few guys that bought them at the local track said that the rear end has a lot of play and the parts don't fit as good as they used to.
Addicted since 1995!!
VBC D07, VBC D08, MTS FF Pro, Calandra 1/12 XTi, SCMT Warpath, AE RC8B3e
Heathen is offline   Reply With Quote
Old 08-27-2008, 10:06 AM   #34
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
I am pretty happy i bought the t4 you sold me. I notice the shock shaft thing with my b4 which is 3 months old and the perfect shafts on my t4 which is coming up a year old.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 08-27-2008, 10:22 AM   #35
Tech Legend
Wild Cherry's Avatar
If anything from my experience the gold shock shafts wear longer and are smoother then the old unobtainium shafts ....
and
How bout the new Transmission main gear and top shaft or the improved outdrives ?
oops ..
You guys forget the new wheels ?
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-27-2008, 10:32 AM   #36
and
oops ..
Naa he mentioned the new wheels, Those new shafts definitly wear faster. I could fire up some pics but i am too lazy.
Whats different about them outdrives and topshaft ?
Old 08-27-2008, 10:40 AM   #37
Tech Legend
The top is coated
and the out drives are harder, so they wear better, just like the Gold shock shafts ....
George W. Cherry
Old 08-27-2008, 11:00 AM   #38
The the out drives are harder, so they wear better
The black "lightweight" ones? I changed over to the raw grey outdrives for the RC10GT a few years back & still haven't worn them out, so I'm a little behind on the new models.
Faster Than Factory
Old 08-27-2008, 11:23 AM   #39
Tech Legend
The old grey does not wear near as a good as the new black, grey were heavier than the lite ones your familiar with however.
That's why grey was preferred.
The new black drives weight is not much different from the grey, so that why I use um now...
also
the black drives make for a smoother diff that wears better specially with the Gt-2 main gear now included ...
George W. Cherry
Old 08-27-2008, 03:40 PM   #40
T4 in the black box are maybe those made in taiwan by thunder tiger ? Like the RC8
Mister-T is offline   Reply With Quote
Old 08-27-2008, 06:37 PM   #41
Heathen's Avatar
sssssshhhh... That is top secret info you are leaking out...
Old 08-27-2008, 11:46 PM   #42
d16dcoe45's Avatar
Just to clarify: on the older T4 I was referring to the "glossy" ti-nitride (gold) shafts, not the carbonitride (grey) shafts that came on the latest bj4 we, and I assume very old Ft t4/b4. The new gold shafts have a dull, matte look to them--and are ok but not like the old shafts. Also, the new shocks seemed to be machined incorrectly as it is very easy for the shock cartridge to pop up and let all the oil leak out. I don't think its a problem with the plastic clip, I think the shocks are machined wrong. The shocks ends will split right down the mold parting line if you aren't careful installing the shock eyelet ball--on the new cars.
Also, another crappy new part is the tan diff gear. I am still running the entire original trans in my t4 which is about 16 months old now and has gotten alot of use/abuse. The black diff gear is perfect as is the original idler and original top shaft. The tan diff gear simply doesn't last that long.
One more thing is that on the newer steering racks it seems on of the cranks isn't molded perfectly straight--so when you put the bearings in it and tighten it down it actually binds on one of the rack screws because the bearings are not sitting inline. When I installed a new rack on my t4 I had to use one of my old cranks to eliminate the binding. Every new rack I have seen has had this issue. The steering will bind big time if you use all the new parts.
The rubber sealed bearings are honestly some of the cheapest, worst bearings sold in any kit I have come across. They truly are cheap junk. I always thought the old teflon ones were a pretty nice bearing but now I just get the $1 Avid ones and chuck them when they get a little rough.
The new style B4 wheels are flimsy and made of a brittle material. I liked the orignal ones better but I always thought the Losi wheels were/are better than both--I ran those even with my b4.
The anodizing is different on the newer alloy parts. There are alot of little differences throughout the entire car.
I had an older box T4 I sold to a friend a while ago, if I still had it I am sure I could get more than retail for it. If you come across an old white box b4/t4 sealed kit, jump on it. Its a superior car to the new ones.
Jay Lestingi
Old 08-28-2008, 06:07 AM   #43
Heathen's Avatar
I think the one I am looking at in the LHS is in a white box. I will have to have a look next time I am there.
The more posts I read the more it seems like the RC10T4 is having the same growing pain as the XXXT with all the stuff being made over seas now.
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
rc10t4 vs. xxx-t cr BSS07 Electric Off-Road 27 03-01-2008 12:22 PM
F/S - Lipo 4800, Novak 4.5 & 6.5, Kyosho SP2 - SELL OUT ALJR R/C Items: For Sale/Trade 30 10-29-2007 07:59 PM
Good starter Stadium Truck? joe of loath Electric Off-Road 35 07-28-2007 12:32 PM
Team Associated RC10T4 Factory Team NIB raydog R/C Items: For Sale/Trade 45 07-04-2007 12:10 PM
Speed limit on GTB dorick Electric On-Road 32 06-04-2007 06:20 PM
