sbv2 bevell gear
sbv2 bevell gear
Where can I find these? I would like to be able to order more then 2 at a time since shipping is like $10 each time I make an order. Will any of these that are actually in stock work w/ the buggy?
https://secure.modelrectifier.com/se...ch-results.asp
https://www.ssl-stormerhobbies.com/c...ns&pn=ACDVP005
Just happen to have 2 in stock too!
I want to order like 10 of them so that I don't have to keep paying $10 in shipping chargers every time I order two gears.
I would contact Tim@MRC if you need that many bevel gears. You may need to loosen your slipper or re-shim your diffs if you burning through that many.
What, & order just two bevells so that I have one spare untill I get to spend $20 on two more bevells a month from now?
It's definitely not normal to be burning through that many bevels - something else is wrong and they're just the symptom. In addition to the adjustments listed above, make sure you drive gear isn't chewed up and check the bearings, it might be sloppy allowing for too much play under load
I've decided to just order an rt-4 & make those diffs fit.
