Gearing for xxx-t
Old 08-19-2008, 12:20 PM
fairlady1288's Avatar
Default Gearing for xxx-t
Was wondering what kind of gearing I need to run with a xxx-t an novak 6.5
fairlady1288 is offline
Old 08-19-2008, 12:33 PM
Briguy's Avatar
Trader Rating: 125 (100%+)
Which xxx-t do you have and what spur gear are you running ?
Briguy is offline
Old 08-19-2008, 12:34 PM
nsane's Avatar
Give this a look:
http://www.teamnovak.com/tech_info/b...r_gearing.html
Its relatively accurate.
So assuming stock spur which is an 82 I believe a 17 would put you at a 11.72, and an 18 would be 11.07 so depending on the track somewhere in there is probably a good start.
Spur / pinion * internal drive ratio = final gear ratio
82/17*2.43=11.72
All that assumes an xxx-t cr w/ an 82 of course..
nsane is offline
Old 08-19-2008, 01:50 PM
damn-yankee's Avatar
Like nsane said... 82/17 temps good and is wicked fast for 2wd.
damn-yankee is offline
