Old 09-03-2003, 02:38 PM   #1
Default General diff question
Why, in off road racing, should diffs be set so tight? Wouldn't that make them harder to drive in the corners
igkyoa is offline   Reply With Quote
Old 09-03-2003, 03:19 PM   #2
glypo's Avatar
If it was loose the car wouldn't go anywhere.
Diffs distribute power to the easiest thing to turn. For example if you put one wheel on the ground and the other in the air the one on the ground wont move at all, but the one in the air will spin happily. With on-road all wheels are always on the ground.
So if you think about it offroad tracks are bumpy. So if one wheel bumps off the ground (or for whatever reason dosn't have full contact with the ground, which obviously happens a lot in off-road) all the power will be transfered to that wheel but not to the one on the ground and the car just wouldn't go anywhere fast. Also with loose surfaces the same thing applies so when there is less grip on one wheel it will spin more then the one with more grip. (which is pointless because it gives most power to the wheel with least grip)
This obviously creates a very in-effcient diff and will not only slow the car down but because of the extremley heavy usage melt it.
Thats why the diffs are tight to stop this un-necesary diff action. Whereas tarmac are flat and solid so on-roads have problems with bumps and loose surfaces.
Hope this makes sense
glypo is offline   Reply With Quote
Old 09-23-2003, 01:34 PM   #3
figure, if your going up a steep hill with loose dirt... what usually happens? The one wheel stops and the other spins and digs into the ground getting you stuck... thats probably why you dont want it too loose. Sure the handling is reduced around corners etc., but on off-road with dirt and grass and whatever i dont think you'll notice it much.
prestonrice is offline   Reply With Quote
Old 09-27-2003, 01:06 PM   #4
thanks I have been running my diff a little loose to help in the turns but i think i may hav been losing power.
Old 09-27-2003, 04:34 PM   #5
losi jon's Avatar
how tight or loose your diff is, is actually another tuning option. to a point! you don't want it too tight or too loose.
losi jon is offline   Reply With Quote
Old 10-12-2003, 09:16 AM   #6
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
you need them tight for better traction in loose soil or sandy conditions..also works great in hard packed too
2mcgrath is offline   Reply With Quote
Old 10-13-2003, 03:42 PM   #7
thanks for all the input i have been turning faster lap times since i re tuned my diff
Old 10-13-2003, 03:47 PM   #8
lmunno's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to lmunno
lmunno is offline   Reply With Quote
general gearing question trdsupra88 Electric On-Road 3 10-01-2007 12:12 PM
General question/experience J.Gonzalez R/C Items: For Sale/Trade 22 12-31-2006 08:05 AM
General question Secret_weapon Electric On-Road 1 10-08-2005 06:44 AM
General Electric question bvoltz Rookie Zone 10 09-07-2005 11:12 AM
just a general rookie question BoneHead Rookie Zone 9 12-13-2004 11:08 AM
