Old 08-18-2008, 11:47 AM   #1
$Tmoney$'s Avatar
Trader Rating: 28 (97%+)
Default lipo cuttoff and orion lipo need help!!!!
how do i get it to work cause the orions have like a hole to balance and the lipo cutoff has three prongs to plug into how do i get this to work a link to what i need would be great thanks guys
$Tmoney$ is offline   Reply With Quote
Old 08-18-2008, 12:25 PM   #2
Mr. devenwhite's Avatar
If you buy the Team Orion Avionics Stability Balancing System you can modify the wire harness to fit your battery.
This web page will show you how.
http://www.teamorion.com/orion/faq/harness.gif
Mr. devenwhite is offline   Reply With Quote
Old 08-18-2008, 02:26 PM   #3
stitchy's Avatar
Which lipo cutoff are you using? Hopefully not the Novak or Liposhield, because neither of those has worked for me.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 08-18-2008, 02:32 PM   #4
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I`m not happy to hear that , I just ordered two Novak cut offs .
What problems did you have ?
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-18-2008, 02:34 PM   #5
Trader Rating: 67 (100%+)
I have two Novak XBRs with internal Lipo cutoff and two external Novak Lipo cutoffs and all have worked perfectly for me. I external is 2S and 1 is 4S.
nutz4rcyktw is offline   Reply With Quote
Old 08-18-2008, 02:44 PM   #6
stitchy's Avatar
Well, I was saying the Novak cutoff and Liposhield don't work with the Traxxas Slash, which I know $Tmoney$ has.
http://www.teamnovak.com/tech_info/i...tes/index.html
Now that I read his post again, it's not clear whether he's using it on his Slash or not.
The Novak cutoff should work with everything else.
Old 08-18-2008, 02:49 PM   #7
Briguy's Avatar
Oh , ok . I just ordered two Orion lipos and a two novak cutoff . Both my escs they are going into are novak , so shouldn`t have any problems . I hope .
Royal R/C & Hobby
Old 08-18-2008, 03:04 PM   #8
$Tmoney$'s Avatar
i havent ordered any cutoff yet but im wondering how it would work with an orion lipo since they use the tap hole instead of the wire coming out of the battery what one has worked with the slash?
Old 08-18-2008, 03:04 PM   #9
$Tmoney$'s Avatar
it is going on my slash
Old 08-18-2008, 03:46 PM   #10
stitchy's Avatar
Both cutoffs work pretty similarly (although again, on the Slash the Novak and Liposhield won't work very well, causing throttle to stutter badly).
The cutoff has a plug that goes into the receiver. The esc plug that normally goes into the receiver goes into the cutoff.
Lastly, the cutoff has a positive and a negative wire that goes into the ESC red and black outputs.
The balancing port is never used.
Old 08-18-2008, 04:08 PM   #11
Briguy's Avatar
Originally Posted by $Tmoney$ View Post
i havent ordered any cutoff yet but im wondering how it would work with an orion lipo since they use the tap hole instead of the wire coming out of the battery what one has worked with the slash albert?
What does the balancing port have to do with the cutoff ? The cuttoff goes between the esc and rx .
Royal R/C & Hobby
Old 08-18-2008, 05:19 PM   #12
$Tmoney$'s Avatar
ooooo for some reason i thought it used the balancing port i dont no what i was thinking i heard that the novak one works on the yellow xl-5 but for some reason it doesnt work on the blue one novak is currently tring to work that out
ORION 3400 LIPO vs. ORION 3200 LIPO SWTour Electric On-Road 3 10-20-2008 11:46 PM
Novak GTB w/ LiPo cuttoff 13.5 SS motor dzstr R/C Items: For Sale/Trade 1 07-25-2008 05:22 PM
WTB: Orion Lipo or other hard case lipo. BADAZZPSD R/C Items: Wanted to Buy 5 02-29-2008 07:01 AM
FS: NIB Novak GTB ESC W/LiPo Cuttoff rcarmchl R/C Items: For Sale/Trade 15 12-11-2007 11:13 AM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
