Old 08-18-2008, 01:43 AM   #1
Default MOTOR NEEDED: Something faster than CM5700 on 3s Lipo??
I have a MM with a CM5700 motor in my FT T4 on Maxamps 6000mah 3s. I am running to hot for my tastes and actually have not quenced my thirst for speed. I want a motor that is FASTER than my 5700 and hopefully has better temp control. Is there such a thing on the market? Also I think my 5700 has lost a little zip do to thermals I believe. I have not had too many cutouts but its hot where I live and high temps are inevitable this time a year. I have a temp gun and I try to keep an eye on it but the temps have snuck up on me a few times. I think a new motor is in order...and I need suggestions. Cheaper is better but if I have to spend the big bucks I will. Oh yea....Im a basher, sure thats obvious. lol
PIMPED RC is offline   Reply With Quote
Old 08-18-2008, 06:25 AM   #2
Do you have a fan/heatsink on the motor? That would help you out a bit!
Just trying to help!
COD
CODMAN is offline   Reply With Quote
Old 08-18-2008, 07:04 AM   #3
badassrevo's Avatar
you could try a Neu 1509 motor http://www.neumotors.com/20061222/Home_Page.html
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 08-18-2008, 02:45 PM   #4
Trader Rating: 69 (100%+)
I had no idea neu was distributed by CC
Paul Whalen is offline   Reply With Quote
Old 08-18-2008, 02:50 PM   #5
So if I get this Neu it would be faster and cooler than the CM5700
Model# 1509/1D 6700KV 7.48/7.94 2.1 0.002 6 $205
and capable of 3s lipo???
Does it still take forever to get one of these motors?
Old 08-18-2008, 03:45 PM   #6
badassrevo's Avatar
Call Neu they are very helpfull and will help you out. Yes it will be faster and coller than your 5700. You might have to drill out the hole in your pinions to 5mm but no big deal. Ask them whst size out put shaft.
Doug Lightcap
Old 08-19-2008, 06:07 AM   #7
6700kv on 3s Lipo?? You had better get transmission gears made out of Diamond, because this thing is going to rip...
Well, whatever makes you happy!
CODMAN
Old 08-19-2008, 11:58 AM   #8
hallj290's Avatar
Trader Rating: 2 (75%+)
Default faster
disable the bec by removing the red wire from the reciver lead and run the 4600kv on 4cell lipo and umm, good luck cause ur gonna have to stock up on tranny parts
Team Losi Racing
Parkersburg Rc Speedway
"Let's Do It In The Dirt"
http://www.freewebs.com/hallj290
hallj290 is offline   Reply With Quote
Old 08-19-2008, 01:13 PM   #9
Why do you need a faster motor? More RPM will not do anything for you except lower the efficiency of your system (more heat, not much more power).
Just gear up.
If you wanna go faster (top end speed) that is.
Get a higher discharge rating battery and set traction control to disabled if you want to have better acceleration.
shurcooL is offline   Reply With Quote
Old 08-20-2008, 01:23 AM   #10
Drifting101's Avatar
Just gear up.
Gear it up i am sorry didnt he just say he had heat problems or did i miss read? 95% of the time you gear to a temp
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
How to get a faster silver can motor? vadersing Electric On-Road 4 06-15-2007 03:33 AM
lipo charger suposedly faster then the 109 party_wagon Electric Off-Road 5 04-30-2007 08:11 PM
what brushless motor is faster SteveJa Electric Off-Road 13 04-18-2006 02:15 PM
new 27t motor... what to do to make it faster the #1 noob Rookie Zone 10 02-14-2006 07:54 AM
which motor is faster? rctc3 Electric On-Road 5 03-10-2002 09:38 AM
