Not again. New Rustler VXL problems. Please Help!
#16
Have you checked the rear wheels to see if you have a broken hub, cross pin, or the like. When one wheel grabs and the other slips, the truck will turn in circles.
#17
Running seven cells you may have damaged the internals in your transmission. It should be inspected to determine if you have anything wrong there. It sounds like the battery is not charging correctly and false peaking is usually a sign of that. Have your local hobby shop put a volt meter on the batt and also get a temp guage and see if it is over heating. If it has been overheated, it may be damaged and not produce power again as it did in the past.
#19
