Old 08-15-2008, 07:54 AM   #1
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Default Thinking abot going lipo and don`t know a thing about them .
I`ve been talking to a few people and think it`s time to get rid of my Nimh batts .
What is the difference between a 25C battery and a 30C battery ?
Was thinking about getting an Orion 3800mAh LiPo Carbon Edition 7.4v Battery, 30C, hard case
Will this fit in my XXX-CR and XXX-T CR ?
A guy at the track said you can run the battery and then put it on the charger right away . You don`t need to let lipos cool down , like nimh ? So I can charge it , run a heat , charge it , and run another ? They need to be charged 1C , right ?
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-15-2008, 07:58 AM   #2
badassrevo's Avatar
Yes to all of your questions.
Buy one good battery, charger and balancer and you are set.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 08-15-2008, 07:59 AM   #3
Briguy's Avatar
ok , I have an Ice so that is covered .
Royal R/C & Hobby
Old 08-15-2008, 08:05 AM   #4
badassrevo's Avatar
I use this balancer for all my lipos, you can get adapters for any style tap.
http://rclipos.com/TP205V.htm
here is a very good battery that will plug directly into the balancer.
http://rclipos.com/TP5400-2SSRT.htm
Doug Lightcap
Old 08-15-2008, 08:37 AM   #5
Briguy's Avatar
How often do you need to balance a lipo ?
Is the MaxAmps Method Balancer a good one ?
What is the difference between 25C and 30C ?
I also see some lipos with another plug with wires , that for balancing ?
I also see some with that plug and others without it .
Royal R/C & Hobby
Old 08-15-2008, 08:38 AM   #6
Trader Rating: 67 (100%+)
Once you switch you will never want to go back.
The only class I run a NIMH in is a spec class where it is required.
nutz4rcyktw is offline   Reply With Quote
Old 08-15-2008, 09:06 AM   #7
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
Here, I just started making the transition to LiPo and had a ton of questions myself, got a lot of good answers & some links to articles on using LiPo packs & equipment:
http://www.rctech.net/forum/radio-el...urse-lipo.html
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 08-15-2008, 09:33 AM   #8
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
If you decide to go with the Orion Lipo you will not have to balance it for the most part. Find someone that will let you check your battery because more then likely it won't be out of balance.
As far as the 25c and 30c, that tells you how much the battery can put out under load. The higher the number the higher the discharge it can go under load.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics |
Jeremy Potter
yzracer758 is offline   Reply With Quote
Old 08-15-2008, 09:43 AM   #9
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
for orion and trakpower style batteries that have that port setup for balancing, you can get a premade adapter from www.rclipos.com . I believe you just look under balancers.
After reading that thread that OTE posted, please post any more questions you have and people here will be more than happy to help. I was in the same boat as you onetime, and was going with a bigger battery setup (4S) for a 1/8 scale conversion.
once you get the hang of lipos, they are really easy to take care of properly.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 08-15-2008, 09:44 AM   #10
Wth, a 2s 5400 mAh 20C hard-cased Lipo battery that weighs only 157 grams!?? This can't be right! Most hard-cased 2s 5Ah Lipos I've seen are about 250-300 grams.
Is it true or just a mistake? Maybe it should've been 257 grams, a typo?
shurcooL is offline   Reply With Quote
Old 08-16-2008, 05:58 AM   #11
Briguy's Avatar
Would I be able to just get one lipo for both my cars or should I get two ?
Royal R/C & Hobby
Old 08-16-2008, 10:00 AM   #12
I would get 2.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 08-16-2008, 10:32 AM   #13
So I take it this doesn't strike anyone else as even a little strange? Hmm, okay then.
Old 08-16-2008, 04:40 PM   #14
The weight can be very different depending on the way the batts are covered (hard shell vs soft vinyl). Also the material inside the cells can be quite different.
Old 08-16-2008, 05:16 PM   #15
Are you saying you think that battery really weighs only 157 grams? It's hard-cased, 5400 mAh and 2S.
Some comparisons of other well-known hard-cased batteries:
TrakPower 4900 2S Lipo - 268g
Team Orion Platinum Edition 4800 2S Lipo - 285g
Enerland Racing PQ-5000MXQ 5000 2S Lipo - 296g
Can it really be that much of a difference?
was thinking of getting one BigPapa Electric On-Road 2 09-03-2008 10:43 AM
New here, thinking about an RC8 RTR... Furadi Nitro Off-Road 3 03-13-2008 07:41 AM
I wonder what he is thinking??? Marcos.J Chat Lounge 16 09-13-2007 10:14 PM
Thinking on a MBX5R jchas26 Nitro On-Road 1 08-28-2007 02:07 PM
Workshop Tabletop CNC machine?!! Are you thinking what I'm thinking?? CLUBCONCEPTS Canadian R/C Scene 6 01-24-2007 10:13 PM
