Old 08-11-2008, 04:36 AM   #1
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
Default Spring PreLoad
How do you judge the amount of preload needed or desired? I run an average bashing session with my Traxxas Slash and I have really no idea about the amount of preload I need or what to look for to judge the amount needed or required.
RCRat is offline   Reply With Quote
Old 08-11-2008, 05:05 AM   #2
sosidge's Avatar
Just use the spring collars to adjust ride-height. Never pre-load an off-road car (ie so it has no suspension downtravel) as it will absolutely ruin the bump handling.
Old 08-11-2008, 05:48 AM   #3
RCRat's Avatar
So I would assume then that the Slash "bottoming-out" is no big deal...seems strange to me that a suspension would "bottom-out" like that...Maybe I'll play with different weight shock oils or stronger springs. Anyone else having problems with the Traxxas Slash "bottoming-out"?
Old 08-11-2008, 07:54 AM   #4
Suspended
As sosidge mentioned, the spring clips are primarily for adjusting ride height and adding a whole bunch of them to eliminate bottoming out will just make your truck bounce crazily when landing as the shocks aren't allowed to do their thing. What you need to look into is changing the shock oil to a heavier weight oil, or just heavier springs, and that will keep the shocks from cycling so quickly and allowing the truck to bottom out like it's doing.
szakcajaru is offline   Reply With Quote
Spring Steel T Plate/Shock spring Question jnor Oval, Larger Scales and More 3 04-15-2007 03:12 AM
charger, servo, xray spring, ae spring, mod and 19T motor....etc maximebeauvais R/C Items: For Sale/Trade 0 01-28-2007 10:24 AM
xray spring, AE spring, drop block, sevo, motor, pinion, power supply, brush cutter maximebeauvais R/C Items: For Sale/Trade 3 01-25-2007 02:09 PM
Motor, Brush and Spring tools, incl. Spring Thing rccardr R/C Items: For Sale/Trade 4 10-22-2006 12:11 AM
Droop and Preload questions R_Andersen Electric On-Road 9 03-23-2002 07:56 AM
